i put 6 qts of oilow oil leak!!! plz help!
Old Apr 6, 2008 | 10:10 AM
cipher's Avatar
cipher
Exclamation i put 6 qts of oilow oil leak!!! plz help!
i just did an oil change last week and i put 6qts of oil in it (penzoil). now, i just went on a good cruise lst night flooring it here and there, kinda being rough on the car and i started to smell burning oil in my car.
So i get up today and i see a small splash of oil on my garage floor about the size of my hand. I jack up the car and everything seems to be fine near the oil plug and the filter, there was no oil near there.
problems seen:
1. behind the oil plug on the bottom of my car there is another black piece near the tie rods and there is a continous drip of oil coming. every 10 second one drip! i dont know exactly where!
2. I have a cold air intake and i saw some oil splashes on it, nothing major.
3. oil cap on the engine is snug and secure.
right behind my fenderwall of the driver side is like covered in oil like someone tire wet the fender lining.
you guys plz help, hope i didnt mess up my car!
Old Apr 6, 2008 | 10:14 AM
Jay'Z's Avatar
Jay'Z
U check around the plenum gasket and around the injector area?
Old Apr 6, 2008 | 10:15 AM
cipher's Avatar
cipher
i will go and check now
Old Apr 6, 2008 | 10:17 AM
Jay'Z's Avatar
Jay'Z
If not, your saying its going behind the drain plug? Id check around the entire block, especially the head gasket.. Just read ur sig.. 100 shot of nitrous couldve playd a part..
Old Apr 6, 2008 | 10:18 AM
cipher's Avatar
cipher
nothing on the engine, its all below the car...i do have 1 step colder plugs from my previous nitrous days.
Old Apr 6, 2008 | 10:19 AM
cipher's Avatar
cipher
took the nitrous out a year ago. did i put too much oil in? yea its way behind the drain plug, right after the y pipe
Old Apr 6, 2008 | 10:20 AM
Jay'Z's Avatar
Jay'Z
U check ur dipstick level? where is it at?
Old Apr 6, 2008 | 10:21 AM
cipher's Avatar
cipher
stick level is fine...its on the top reading.
Old Apr 6, 2008 | 10:25 AM
Jay'Z's Avatar
Jay'Z
Ok, just read ur op.. Why in the hell would u put 6 quarts in? Secondly 5 quarts, and im still left with oil in the 5th quart bottle.. U sure its not just oil that spilled and now its just draining off after the oil change.. clean the car up well and find the source.. Thats ur only hope or just drop it off at the stealership..
Old Apr 6, 2008 | 10:26 AM
cipher's Avatar
cipher
thats what i am thinking too. but if i did put too much oil where would the extra release from?
Old Apr 6, 2008 | 10:27 AM
Jay'Z's Avatar
Jay'Z
Lol.. I cant believe u did that.. hold up.... Be careful not to overfill your Z wit oil... If you put in too much oil, the engine's crankshaft can actually come in contact with the oil and because the crankshaft is turning at several thousand revolutions per minute.. It can quickly whip your oil into a froth, like the steamed milk that sits on the top of a cappuccino... Why is that bad? Well, the oil pump wont pump froth very well, and as a result, it can't get oil to the parts of the engine that need lubrication.. The result ... a hefty house payment to your mechanic...
Old Apr 6, 2008 | 10:29 AM
zand02max's Avatar
zand02max
Why would you put 6 qts in?
Old Apr 6, 2008 | 10:38 AM
Jay'Z's Avatar
Jay'Z
After reading the OP the second time.. I said the exact same thing..
Old Apr 6, 2008 | 10:39 AM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
You put too much oil in. If you put too much in, oil gets up into the crank where it's not supposed to and starts foaming, which can cause a butt-load of problems. Your best bet is to change the oil again (let it drain for extended period) and then put in 5 quarts.
Old Apr 6, 2008 | 10:45 AM
cipher's Avatar
cipher
i know im an idiot!!! i am draining the car as we speak
Old Apr 6, 2008 | 10:48 AM
Jay'Z's Avatar
Jay'Z
Cool.. Fill it right this time..
TreeFiddyZee
Do WHAAAAT!?
Originally Posted by cipher
i know im an idoit!!! i am draining the car as we speak
As long as you admit it, then we've done our job. GL
Old Apr 6, 2008 | 10:58 AM
cipher's Avatar
cipher
oil that is draining looks very new an clear. do you think im ok or will i have to wait and refill the oil again and then see if it still leaks?
I just wanna say thanks guy for helping me out, i really appreciate it.
Old Apr 6, 2008 | 11:00 AM
Jay'Z's Avatar
Jay'Z
Did u drain it entirely and put back the 4.8 quarts or whatever.. Not 6.. Not even 5 exactly..
Old Apr 6, 2008 | 11:08 AM
cipher's Avatar
cipher
still draining, i am going to get oil from the store right now and i will put in 4.8 only.
apex locator
Jul 23, 2021 02:27 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
