no start issues
Old Apr 12, 2008 | 01:53 PM
D15na's Avatar
D15na
Default no start issues
my 04 z has had the engine out of it for roughly a year. a month ago i put a new engine in it. (without a filter on it)it started, ran for 5 seconds and shut off. started, ran for 10 sec shut off. started ran for 30 sec, shut off. then i went to Africa for a month. when i came home, i started it, drove it for roughly 2 min and turned it off, installed popcharger, and strut bar. started, ran for 10 seconds, shut off. wont start now. i tired starting it for roughly 3 minutes put together. i tried plugging in the white box under the cd player but didnt change a thing. the dte says 23miles. could it be out of gas?
Old Apr 12, 2008 | 01:56 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
maybe gas, but i doubt it, sounds like a bad ecu
Old Apr 13, 2008 | 08:01 AM
D15na's Avatar
D15na
like it could possibly have gotten fried by a short possibly?
Old Apr 13, 2008 | 10:00 AM
MI 35th's Avatar
MI 35th
OGPremierMafia
Yes very likely. Also is it the original ECU, if not it could just be the imobilizer not allowing the car to run.
Old Apr 14, 2008 | 03:50 PM
D15na's Avatar
D15na
original ecu...where is this immobilizer located?
thanks
Old Apr 15, 2008 | 01:14 PM
D15na's Avatar
D15na
it seems the maf has to go a certain way..ie - pointed at driver side fender well.... not sure tho, the bat is extremely drained and charging now
Old Apr 22, 2008 | 08:22 AM
D15na's Avatar
D15na
ok, so i pulled the plugs after doing the idle learning prodecure, and plugs a soaking wet. could it be a possibility that the 440's i have in it are too large for no boost/ tune? im reluctant to change then as the shop i had the TT kit installed on cut the injector plugs about a 1/2" from the plug.
Old Apr 22, 2008 | 03:45 PM
Corradoslc7's Avatar
Corradoslc7
Are you still having a problem starting the car or has it fired up yet? If your engine hasn't been started yet and you have been attempting to start it, then yes there will be a lot of unburned fuel in the combustion chamber(ie: on the spark plugs.)
Old Apr 23, 2008 | 01:38 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
ok I definately missed the point where you had roughly double the injector in there with no tuning... Your car is flooding! Its choking without enough air in there.
Old Apr 27, 2008 | 07:04 AM
D15na's Avatar
D15na
thanks...turns out my uncle had a scan tool, so we scanned and got the p0335? crank sensor A. would this cause it not to start?
Old Apr 27, 2008 | 12:03 PM
Corradoslc7
yeah a crank sensor could cause a no start problem.
Old Apr 29, 2008 | 11:50 AM
D15na's Avatar
D15na
thanks, from the description in the manual, it sounds like it monitors the flywheel?
Old May 13, 2008 | 05:42 PM
EnduroMTS's Avatar
EnduroMTS
Any luck? Did this ever get resolved?..
Old Jun 1, 2008 | 05:13 PM
D15na's Avatar
D15na
ran into some time road blocks, ill know soon
Old Sep 18, 2008 | 11:22 PM
ADMAN's Avatar
ADMAN
Yep, P0335 is EXACTLY why it won't start. Worse when that sensor sits and gets cold. Opposite of what you would think. Heat Soak is your FRIEND with that POS.
Don't ask me how I know...
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
