Air leak in driver-window
Old Apr 21, 2008 | 08:30 AM
Mr. Famouz's Avatar
Mr. Famouz
Default Air leak in driver-window
I recently installed new speakers in my Z. I also upgraded the tweeters. Since then I can hear an air leak in the corner where the tweeter panel is. I know i put everything back on right. So what could it be? I'm thinking it might be the rubber seal around the panel. Any advice?
Old May 12, 2008 | 06:03 AM
RedBullRR's Avatar
RedBullRR
Bump for this as it drives me crazy as well. Not super loud but you can def hear it at certain speeds.
Old May 12, 2008 | 12:26 PM
coldchylln's Avatar
coldchylln
I bought my car in march, and noticed this problem. Water also leaked through at touch-free car washes with the high power water jets. they installed new weather stripping, but I still have the same problem. There are a few threads on here about the window regulator causing this issue.
Old May 12, 2008 | 03:58 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
I have this problem as well. I was thinking.. Would readjusting your windows to close up higher solve this? After the dealership did the TSB on my windows, I think they positioned the windows a bit lower than it's supposed to sit.
Old May 20, 2008 | 12:14 PM
RedBullRR's Avatar
RedBullRR
I'm still not sure it still is a problem. Seems to be coming from the mirror, not loud but enough to **** me off. I mean that **** happened in my integra, this is a new car dam it!
Old May 21, 2008 | 04:17 AM
RedBullRR's Avatar
RedBullRR
bump
Old May 21, 2008 | 11:29 AM
tonyrd1's Avatar
tonyrd1
got the same thing happened, it get really annoying now
Old May 22, 2008 | 05:42 AM
RedBullRR's Avatar
RedBullRR
I'm ready to start taping **** up just to find out what area its coming from. Its not loud but I can hear it and I shouldnt. LOL
Old May 24, 2008 | 01:59 PM
Jahrawi's Avatar
Jahrawi
that's annoying i have the same problem from the driver side, specially if i go over 60.. took the car to dealer got the rubber adjusted and like 2 screws changed, left the dealer .. same problem! nothing changed.. they just said most Z's are like this and even if they change all of the rubber frame it will be the same in 2-3 months..
Old May 29, 2008 | 08:03 AM
Bret86944's Avatar
Bret86944
I noticed the same thing. When I push on the rubber stuff from the inside it seems to go away. Either the weatherstipping is not pusing against the window hard enough or the window is not going up completely.
Old May 30, 2008 | 05:38 AM
langtubip's Avatar
langtubip
not fast enuff
i got some problem on my 05, my solution for this is to crank the music up.
Old May 30, 2008 | 06:20 AM
RedBullRR's Avatar
RedBullRR
I put the music up to, but come on there has to be a reason for this. It sounds like it comes thru the mirror.
Old May 30, 2008 | 08:18 AM
j.arnaldo's Avatar
j.arnaldo
Most of our monZters suffer from 3 "little annoyances": 1. Power window motor(s) work part-time. 2. Faulty hatch door strut(s). 3. Gas latch release
thingie (i.e. you have to depress the button various times to get the gas door open). Otherwise, I LOVE MY ZED!
350Z_Al
Oct 29, 2020 07:44 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
