Engine Shuts Off While Driving
Old Apr 25, 2008 | 10:24 PM
oneradtek202's Avatar
oneradtek202
Default Engine Shuts Off While Driving
So i just put on a k&N cold air intake on my 03' Z. Everything done 100% correctly and everything tight. But since i installed it , when i have it in neutral while down shifting for the stop, my engine will shut off. I had the nissan dealership check for stored codes, but this has happened 3 times in the past week. Im going to reset my ECU, and clean the MAS and see if this helps?
any other suggestions?
Old Apr 25, 2008 | 10:40 PM
flynbrin's Avatar
flynbrin
search
Old Apr 26, 2008 | 05:24 AM
oneradtek202
i actually spent 2 hours last night trying to find another thread related to an engine shutting off while driving, the only other one i found ive been posting on but it has a bad title/description of it so i made my own
please post a link to a thread about this issue if u know of one other than these
Old Apr 26, 2008 | 05:53 AM
Patient: My arm hurts when I go like this.
Doctor: Then don't do that.
Old Apr 26, 2008 | 06:11 AM
oneradtek202
aka bad/dumb doctor......car never did this before the typhoon intake was installed
Old Apr 26, 2008 | 06:14 AM
raf84ny's Avatar
raf84ny
I've read somewhere that some people w/ JWT Popchargers had the same issue. I'll try to look for that thread.
Old Apr 26, 2008 | 06:18 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
+1 reset ecu?? for an intake??? IMO it's waste money, stock airbox is working good as well.
Old Apr 26, 2008 | 06:21 AM
oneradtek202
well i couldnt help but not get the parts, i could of made some money off them regardless if i put them on or not.... i got the typhoon and eibach pro springs for $130
Old Apr 26, 2008 | 06:22 AM
oneradtek202
and how long does it take for a ECU to reset once the negative terminal is disconnected?
Old Apr 26, 2008 | 06:34 AM
Corradoslc7's Avatar
Corradoslc7
Obviously the K&N intake is the cause of the problem as your problem started immediately after installing it. So start by cleaning your MAF, the filter was probably over oiled. After that double check your work to make sure everything is tight and there are no leaks. To reset the ECU leave the neg terminal disconnected for a couple of hours and come back, it should have reset by then.
Old Apr 28, 2008 | 07:27 AM
Apologize for my poor attempt at humor. Unless you are shifting, the car should be in gear.
Obadabot
Jun 18, 2023 11:31 PM
3vilbunny
Jul 18, 2017 05:10 PM
