Burning oil?
Old Jul 8, 2003 | 06:53 PM
kj301's Avatar
kj301
Default Burning oil?
On my last oil change I switched over to Mobil 1 at 4622 miles. First time I have every used synthetic oil. I placed 5 quarts in when I changed my oil with a filter replacement.
I checked the dip stick this week (6000 miles) and found that the oil was a little bit darker. I also noticed that I was about 3/4 of a quart down. Do you think my motor is buring oil?
KJ
Old Jul 8, 2003 | 08:04 PM
PhoenixINX's Avatar
PhoenixINX
Motors burn synthetic FAR more rapidly than they do typical oils.
Don't be surprised to see that you're "burning off" oil.
Old Jul 8, 2003 | 09:13 PM
NismoEagleRock's Avatar
NismoEagleRock
Default as for darkness of the oil..
i don't think it's due to the fact that your car is necessarily burning oil. mobil 1 with "super syn" is darker than regular motor oils. it should be a dark copperish color straight out of the bottle when you first pour it into your car. should you be worried about the color? probably not. but do make sure that your oil level doesn't drop significantly.
Old Jul 9, 2003 | 08:41 AM
kj301's Avatar
kj301
I read my post this morning and I ment to say that I am down 1/2 to a 1/4 of a quart.
Old Jul 9, 2003 | 09:29 AM
MGV156's Avatar
MGV156
Default I have the same assessment
The last time I changed my oil, I poured the entire 5 qt container of Mobil 1 5w30 that Wal-Mart sell for $19 and change. I checked my level last week @ 6k miles and the dipstick was down about 1/8 inch from the max. level.
Old Jul 9, 2003 | 03:08 PM
350zdanny's Avatar
350zdanny
you're half way to your next oil change. that is really nothing to worry about. but monitor it further to see if the "burn off" accelerates.
Old Jul 10, 2003 | 10:24 AM
bgumby99's Avatar
bgumby99
Default same amount loss
I just turned 6500mi, and checked mine (as I've been using Mobil 1 since 2000mi). I see the same oil amount drop that you all have quoted. I was wondering if it was a problem as well, but I'm guessing since we are all seeing it, it should be alright
Just my 2 cents
Old Jul 11, 2003 | 01:40 PM
dr_gallup's Avatar
dr_gallup
3500 miles since I put in 5 quarts of Amsoil 5w-30, still within an 1/8" of full mark. Synthetic oil does not burned quicker than dino oil. There is quite a variation in oil consumption rates, yours is not excessive but maybe higher than average. Keep an eye on it and make sure you don't have a leak.
Old Jul 14, 2003 | 06:22 AM
skullslammer's Avatar
skullslammer
Angry smokes at startup
My 2003 Enthusiast 350Z puffs grey smoke at startup. Same thing an engine with high miles will do, but mine has only 6200 on it, has not been abused and has been maintained correctly. This worries me and I wondered if others have this same experience. Doesn't appear to be using oil.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
