problem keeping my car running
Old May 9, 2008 | 06:57 PM
ChikinShyt's Avatar
ChikinShyt
Exclamation problem keeping my car running
When my car is cold and i start it, it will stay running, but after its been warmed up and i start it, i have to rev up the engine so it will stay running or it will just die out on me...can anyone give me some suggestions...thanks
Old May 9, 2008 | 09:20 PM
CSF's Avatar
CSF
Check the engine oxygen sensor. since it's occuring after the car warms up...i'm thinking that there is a problem switching from open loop to closed loop
when the car is warming up...it's running on open loop off mapped data.
when it warms up and switches to closed loop, the oxygen sensor is giving bad voltages or some kind of bad readings.
just my guess.
Old May 10, 2008 | 09:27 AM
Corradoslc7's Avatar
Corradoslc7
just my guess.
x2
Old May 12, 2008 | 10:01 AM
Master Shake's Avatar
Master Shake
Also check the MAF. I had the same problem (low/rough idle when warm) and was able to get a new MAF (through warranty, luckily!) Usually, the MAF just requires cleaning. Apparently, my MAF was actually bad (which seems to be somewhat common here).
Old May 12, 2008 | 10:51 AM
My350P's Avatar
My350P
For a third possibility, after installing my plenum spacer I was having the exact same problem, and it appeared to be caused by vacuum leak from the plenum bolts not being tightened all the way.
Old May 14, 2008 | 04:11 AM
ChikinShyt's Avatar
ChikinShyt
anyone think it could be the throttle positioning sensor? i just got a service engine soon light and when i did the diagnostics, it said that my TPS was bad..
Old May 20, 2008 | 06:35 AM
ChikinShyt's Avatar
ChikinShyt
Smile Fixxed
Just incase anybody was wondering, i changed my throttle body and sensor and it fixxed the problem, my "service engine soon" light is also gone...thanks anyway for the suggestions
pslamp32
Feb 8, 2017 09:07 AM
Juztin
Nov 22, 2015 07:03 AM
SanmarinoZ
Oct 21, 2015 10:04 AM
PureR3d
Sep 10, 2015 06:23 PM
