Brake Fluid
Old Oct 12, 2012 | 05:48 PM
Chi-TownWarrior's Avatar
Chi-TownWarrior
No need, cluch never heats up the fluid enough. Probably would use something else on an 07/08 with the slave in the bell housing
Makes sense, but I wouldn't do that myself. I learned my lesson on buying cheap when I bought Stance.
I was only asking out of pure curiosity. Glad it works though.
Old Oct 12, 2012 | 06:07 PM
terrasmak's Avatar
Typically it's Valvoline or Prestone, so it's still high quality stuff. Same as I use in all my other vehicles. There is no advantage in running Ate or Motul in my clutch. Now a car with the headers closer to the slave/line , slave in bell housing or other factors , Yes I would use it.
Also the normal Dot 4 fluids last longer
Old Oct 12, 2012 | 09:32 PM
taywan's Avatar
taywan
I have 1 L of the super blue. I'm installing a bbk on the Z. Curious about this. Lasting longer but having to change fluid more often then? Or? Just curious. Worth putting it in? Normal driving-nothing extreme at all.
Old Dec 21, 2012 | 09:50 PM
srsairbags's Avatar
srsairbags
just did a brake pads/rotors replace and bleed . . the shop said it took only one bottle of Motul RBF 600 (which is 500ml, one qt approx) . I was expecting it to take 2 and a half bottles.
I am confused, is the old fluid still in the system ? Mine is a 07 HR Non - Brembo
Do i need to do a full bleed again to make sure all the old fluid is out ?
lapham3
Oct 7, 2022 03:15 PM
samansharif
Sep 25, 2015 12:31 PM
