A/C Problems after A/C kit install
Old Jul 14, 2003 | 07:12 PM
emu29's Avatar
emu29
Default A/C Problems after A/C kit install
Re the TSB regarding the A/C noise...The dealer ordered and A/C kit per the TSB. Installed it last week. Over the weekend I had a problem with the compressor cycling off periodically at idle and not coming back on for 5-10 minutes. Back to the dealer...they said that they had been having problems with their equipment use to meter the correct volumes of freon when replacing same, and as a result they had put to much freon in the system....????
Said that all was fixed (A/C reservices/recharged...got the car back today. The compressor does not cycle off when it is not supposed to any more but the A/C air is not as cool as it was with the old compressor.
I took a cooking thermometer that has an un-metered range below 100 degrees and checked the air vent temperature for 5 minutes in the Z and two of my other cars. The Z appears to be 15-20 degrees warmer than my other cars.
QUESTION: CAN ANYONE TELL ME WHAT THE SPECS ARE FOR WHAT THE AIR VENT AIR TEMPERATURE SHOULD BE WITH THE A/C SET AT 60 DEGREES IN THE Z?????
THANKS.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
Dsowe
Feb 17, 2021 10:38 AM
samansharif
Sep 25, 2015 12:31 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
