Car died!
Old Jun 3, 2008 | 08:08 PM
black3.5z's Avatar
black3.5z
Default Car died!
ok so i took my car out tonight after work after about 5 km of driving my gas light came on. it said i had 50 miles left then after driving about quater of a mile it had dropped 14 miles so i stopped got my food and then went to get gas by the time i hit the gas station it was at 33 so i put 30 dollors supreme in and took off. by the time i got up the street about 2 miles i went to take off from the stop light and it was acting like a person who cant drive a standard all jumpy and stuff my sevice engine soon light came on along with my vdc and slip light. when i went to take off a gain the car woul drev to 3k rpm then start hoping threw the rpms over an array of like 800 high and low so i had to stop again. i shut the car off then turned it back on all the lights were off. so i sat in neutral and reved it a little after it hit 3k rpm again it starting to act like the fuel was being cut off then getting it back again and bogging. then after that it started to do it at 2k rpm i barely got it home
I just had a new clutch masters flywheel and exedy clutch put in the car is a 2004.5 touring model with 32k miles I need help i have to drive this car 5000km home in less then a month thanks.
Old Jun 3, 2008 | 08:12 PM
03Zilverstone's Avatar
03Zilverstone
Ouch, sounds like what I just went through. In advance, I'm sorry.
JoeyFyed's Avatar
JoeyFyed
My car acted the same exact way when my crank shaft posistion sensor went out.
Old Jun 3, 2008 | 08:15 PM
03Zilverstone
Things to start looking
TPS (throttle positioning sensor)
gas pedal assembly
MAF
fuel pump
Start off by using a multimeter to check voltage to the TPS.
As for mine I went through all of that and could find out what it was. Thought it was the ECU and replaced it to no avail. Brought it to the dealer and they tinkered around and said it was the fuel tank rusted up inside. I bought a new tank and was going to do it myself. I drove it down the road there and it did fine so I went ahead and brought it home. That was last week. No problems since.
Old Jun 3, 2008 | 08:18 PM
black3.5z's Avatar
black3.5z
gas pedal assembly
MAF
fuel pump
where exactly is it located i jsut got the car 2 weeks ago
Old Jun 3, 2008 | 08:22 PM
03Zilverstone
It's the sensor on the side of the throttle body.
Do you have the service manual? I have it on CD. I'll try to take a pic of my screen if you want. I don't think it will let me copy and paste it to an image file.
Old Jun 3, 2008 | 08:26 PM
black3.5z's Avatar
black3.5z
ok i will go get my manual, I just read your thread on your car how did it go?
any idea the page number?
roast's Avatar
roast
god forbid it be something simple like bad gas....
Old Jun 3, 2008 | 08:27 PM
black3.5z's Avatar
black3.5z
that is what I began to think but man bad enough to do that
Old Jun 3, 2008 | 08:31 PM
03Zilverstone
If it was bad gas I don't think the revs would fluctuatelike that. It would either just idle like crap or not run.
As for my car all I know is what was in post #4. I'm not really sure. I assume the tank was dirty and they cleaned it up some at the dealer. If it does it again I'll replace the tank with the new one I got.
Old Jun 3, 2008 | 08:33 PM
black3.5z's Avatar
black3.5z
like i siad i did run my car till the gas light came on. i have the battery unhooked right now. I am goin gto plug in my scan tool in liek 2 mins
Old Jun 3, 2008 | 08:35 PM
03Zilverstone
Look at page EC482.
Old Jun 3, 2008 | 08:37 PM
Ztalker's Avatar
Ztalker
yup, .bad gas will do it.
Some independent gas station would mix water in their tanks.......**** happens.
Old Jun 3, 2008 | 08:38 PM
03Zilverstone
Yeah, that's why I was saying I don't think it's bad gas. Let me know what those codes are. I'm willing to bet that atleast one is in common with the ones I had.
black3.5z's Avatar
black3.5z
**** i though tyou mean owner manual. i was kinda thinking why they would have a picture in the owners manual my bad I am gonna go plug my code reader in.
Old Jun 3, 2008 | 08:52 PM
03Zilverstone
Nah, the service manual. I'll see if I can hook you up.
Old Jun 3, 2008 | 08:54 PM
black3.5z's Avatar
black3.5z
ok went back down I had the battery unhooked hoping maybe it was just a ecu mess up well the car idels fine but once it hits 3k rpm it goes all crazy again and bogs out I hooked up the scan tool and it threw no codes. I am unsure tho if that is because there were no lights on.
Old Jun 3, 2008 | 08:58 PM
03Zilverstone
Old Jun 3, 2008 | 09:00 PM
black3.5z's Avatar
black3.5z
ok so the sensor going into that box on the throttlbe body? there are a boat load of wires on that sensor
Old Jun 3, 2008 | 09:04 PM
03Zilverstone
