Blind Spot
Old Jul 16, 2003 | 09:07 AM
sifuK's Avatar
sifuK
Default Blind Spot
hey i was wondering if any of u guys have a prob with the left side rear mirriors. im short 5' 2"and it is a blind spot for me. i almost got into 3-4 accident cuz of that. the left side mirror just blocks my entire view on the side and many times i cant see the cars on my left coming in. do any of u guys have this probblem? is there anyway i can raise my seats.
Old Jul 16, 2003 | 11:22 AM
drback222's Avatar
drback222
I have had the same problem. Seems to be a lack of coverage on the mirror.
Old Jul 16, 2003 | 11:32 AM
drback222's Avatar
drback222
Old Jul 17, 2003 | 08:43 AM
n8vz's Avatar
n8vz
i use the "look and head tilt" method. bascially, look at the side mirrors and tilt you head a few degrees to expand the visible area.
Old Jul 17, 2003 | 10:06 PM
krutoydude's Avatar
krutoydude
Get that small round mirror that goes on top of your original one. I see many older generation Zs with that small mirror. I believe Nissan should sell them.
Old Jul 18, 2003 | 01:56 AM
drback222's Avatar
drback222
This is a sport car, not a big rig.... lmao. someone tell nissan to get their act together!!!
Old Jul 18, 2003 | 11:46 AM
SteveZzz's Avatar
SteveZzz
I think you guys are missing the point. I think the problem is that sifuk is having is not being able to see things in front, not behind because the mirror is blocking the view towards the front left.
Old Jul 18, 2003 | 01:35 PM
Intrepid175's Avatar
Intrepid175
Respectfully folks, the only thing your mirrors show you is what's "behind" you, and then it's on a very narrow line of sight. You "can not" rely on the mirrors to always show you what's beside you. You have to "turn your heads and LOOK!" Even if you buy the little accessory convex mirrors, don't rely on the mirrors exclusively. I can't tell you the number of times I've been beside someone and noticed them glancing at their side mirror, only to have them heading right into my lane a few seconds later. I lay on the horn, they jump back into the lane they came from and then (most of the time, fortunately) are waving "I'm sorry" through the window. If they had simply looked over their shoulder, just a little, they would have seen me.
You'd be "amazed" at what your mirrors DO NOT let you see!!!
Please Drive Safe,
Steve R.
Old Jul 18, 2003 | 01:53 PM
Intrepid175
Having said the above, I reread what SteveZzz said which made me reread sifuk's initial post. I think he is having trouble seeing cars coming up on the left side if I understand him correctly.
Sifuk,
You asked about raising the seats. The only 350Z I've got experience with is a touring model and it has power adjustable seats which means you've got a height adjustment. The other models, according to Nissan's web site, have a 6 way manual adjustment drivers seat. I'd interpret that as having a height adjustment too, even if it's a manual one. Am I wrong on that or do you already have your seat up as high as it will go? If you do, I see no reason why you couldn't unbolt the seat, fabricate some sort of spacers to lift it up and then reinstall the seat. The only real problem I think you should be careful on is ensuring that the bolts are still long enough to adaquately secure the seat to the floor. You obviously don't want only two or three threads holding the seat down. If you do need to replace the mounting bolts with longer ones, be absolutely sure that the replacements are of equal strength to the originals. Hardware, like bolts and stuff, come in different strength or hardness ratings and it's important that the mounting bolts for the seats are up to the task. Having your seat pop loose in an accident would seriously screw up your day! Hope this helps!
Good luck & Drive Safe,
Steve R.
Old Aug 1, 2003 | 06:56 PM
jomaxum's Avatar
jomaxum
Please Drive Safe,
Steve R.
I agree. He should adopt the rule all motorcycle riders know if they are smart. Mirrors say no, not go. You have to turn and look always!!!!!!!!!
Chris350z03
Oct 8, 2023 07:19 PM
pslamp32
Feb 8, 2017 09:07 AM
ablaine
Nov 29, 2016 10:13 AM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Ronso
Oct 30, 2015 12:39 PM
