interior light and mirror lights not working!!
Old Jun 29, 2008 | 04:35 PM
rollnon12s's Avatar
rollnon12s
Default interior light and mirror lights not working!!
I don't get it, I've checked all 3 fuse boxes- and there's nothing. Heard sonething bout a bpm.??? Has any one had this problem, what do I do??!?!?!!
Old Jun 29, 2008 | 04:53 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
Is your window-drop working when you open the door? I had this problem because the rubber boot on the actuator button was pinching. If the rubber gets pinched enough, it will hold the button in not letting the lights come on or the windows to drop. When you open the door, it's toward the rear of the car near the bottom.
Old Jun 29, 2008 | 05:36 PM
rollnon12s's Avatar
rollnon12s
yea it doesn't work even when I push the interior light in.
Old Jun 29, 2008 | 05:55 PM
TreeFiddyZee
Do WHAAAAT!?
Still sounds like a fuse to me.
Old Jun 30, 2008 | 09:11 AM
rollnon12s's Avatar
rollnon12s
WTF!!! I just hopped in the Z and turned the key and the dash and everything was blank, I turned it back and forth, got out, got in, my subs popped hellA hard and the the interior lights turned on after a week of this.
random electrical issue FTW!!!!
Old Jun 30, 2008 | 12:50 PM
ekidd's Avatar
ekidd
battery?
Old Jun 30, 2008 | 01:03 PM
contraststriker's Avatar
contraststriker
If the problem is off and on I lean toward something in the ignition making intermittent contact.
Old Jun 30, 2008 | 06:32 PM
Voboy's Avatar
Voboy
You check the drivers side footwell fuse box right?
Old Jun 30, 2008 | 06:41 PM
Watkins's Avatar
Watkins
It's the BCM, the Body Control Module; I hope that isn't fried, it's not cheap.
Just run a search on BCM for all the info.
Old Aug 16, 2009 | 06:55 PM
Ana350z's Avatar
Ana350z
Default Have you solved the problem?
I havethe exactly same issue with my 350z. The interior lights and mirror lights do not turn on. The windows are working just fine as well as the trunk light. I've checked the fuses and everything seems to be Ok. Please help!!!
Old Aug 16, 2009 | 09:06 PM
Silkfiveseven's Avatar
Silkfiveseven
ftw or ftl....
Old Jun 13, 2012 | 06:41 AM
DeanAZ's Avatar
DeanAZ
Default Dome and mirror lights
Yes, I am having the same problem and have been told that the capacitor has to be replaced. I think they actually call it the BCM. Apparently it costs about $275 for the BCM.
HoBrahYouStink
Jun 24, 2016 10:58 PM
Vigman
Nov 17, 2015 04:34 AM
samansharif
Sep 25, 2015 12:31 PM
