Interior Lighting stops working, please help!
Old Sep 1, 2008 | 08:32 AM
ZKansasZ's Avatar
ZKansasZ
Default Interior Lighting stops working, please help!
So I wanted to replace the doom light by some L.e.d ones. They are 6 l.e.d bulbs in a closed circuit with relay. All I had to to was to hook up the negative and possitive wires to the 2 ends. I tested it and it worked. Now I put the l.e.d in and tried to hook up to the 2 ends again. I think I got the wrong end accidently so I saw a spark, then nothing works...
everything else works but the interior light now. Checked the fuse and they are fine. Tested the L.e.d. on battery power and they are fine, too.
I put the oem bulbs back on and it still does not work...
anyone knows of any other causes and how to fix this problem?
Old Sep 1, 2008 | 08:44 AM
elayman's Avatar
elayman
well i have a g35 so i'm not sure if it's the same, but you should try disconnecting your battery for 30 seconds.. also not sure if this applies to the z's, but we have a fusebox behind the battery, I blew the taillight fuse one time and it caused my taillights, driving lights and clear corners to stop working.. do all your lights work besides your domes?
Old Sep 1, 2008 | 09:28 AM
ZKansasZ's Avatar
ZKansasZ
yup, everything else works but the doom light.
I checked the fuse box and the fuse for doom light is ok still...but still will go replace it just in case...idk
Miguel Albanez
Oct 17, 2022 10:13 AM
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
seagrasser
Oct 11, 2015 03:27 PM
Shane86
Sep 17, 2015 05:33 PM
