Window "Opening" At Freeway Speed?? (*Searched*)
Old Sep 23, 2008 | 09:55 AM
M3ANMACHINE's Avatar
M3ANMACHINE
Originally Posted by Fluid1
Really?
Reeeeeeeeeeeeeally?
OP, I really hope that you are fawking kidding us all. You searched?
Where did you search? In your kitchen? In the elevator at the office?
How about you eagerly check the sticky thread regarding the window motor that none other than our own VO posted. Either that, or your door is ajar
The problem is not the window motor as I already stated. The window works perfectly fine, it opens and closes, it locks, it functions fine other than what seems like a "leak" coming from the window only at high speeds...
Old Sep 23, 2008 | 05:03 PM
LeMans 05's Avatar
LeMans 05
OP, I had the same problem on my '05. Dealer replaced my window motor for me. Unfortunately, they also scratched the 'metal' on my passenger door handle while doing it that they haven't fixed yet, but that's just because they're idiots. New window motor solved the problem.
Old Sep 23, 2008 | 05:11 PM
M3ANMACHINE
Thanks for the help.
Did they give you any information on what the problem actually was?
Old Sep 23, 2008 | 05:52 PM
j1234's Avatar
j1234
check ur weather stripping around the windshield and the window. mine had started deteriorating and i am getting replaced under warranty. i was getting a very similar sound at highway speed....... hopefully this helps and doesnt end up as one of those BS threads that comes up when u search where everyone says use the search... i feel ya
Old Sep 23, 2008 | 06:30 PM
LeMans 05's Avatar
LeMans 05
Probably. I don't always listen very well. IIRC, it was something about the limit sensor in the motor.
Old Sep 23, 2008 | 06:32 PM
LeMans 05's Avatar
LeMans 05
Nah, I know what the OP is saying. At highway speeds, for some reason, the window 'drops' just a bit, like it's lazy. It goes back up with the window switch, but then it does it again. And you play this game for a couple of hours on the highway, and in the end, you want to park the car under the nearest semi truck, because it's driving you out of your ******* mind!!!
But, like I said, the window motor replacement worked for me. GL!!!
Old Sep 24, 2008 | 07:20 PM
j1234's Avatar
j1234
Old Sep 25, 2008 | 07:34 AM
DVFlyer's Avatar
DVFlyer
Speed of White
FWIW- I had this same problem with a '98 C5 Corvette (this was one of the issues listed in my Lemon Law claim). They had an Engineer from Chevy fly in to check out my car.
On a test drive, there was just enough of a crosswind to cause the condition mentioned in this thread. The "engineer's" response was,
"Oh, that's wind rush, not leaking".
I said, "I can put my hand up here and feel wind coming in".
"No, that's just a pressure change", he replied.
Car returned.
IMO- Getting the window to roll up just a few mm more would have solved the problem given that the window would have seated into the seal a bit more.
Siqcology
Sep 18, 2019 01:45 PM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
codek
Sep 28, 2015 03:03 AM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
AP350z223
Sep 8, 2015 04:38 PM
