Gas Milage Depleting Rapidly, False Gas Reading. PLEASE HELP!!!!!
Old Oct 10, 2008 | 12:20 AM
rafael2201's Avatar
rafael2201
Default Gas Milage Depleting Rapidly, False Gas Reading. PLEASE HELP!!!!!
I'm at the gas station put a full tank of gas in but gauge never reads full. Gas meter also goes up and down. Was able to get 350 miles + on one tank of gas now just over 250 MILES ON ONE FULL TANK OF GAS. Whats the problem do in need a new fuel filter? TSB problem? Please Help me!
Old Oct 11, 2008 | 12:03 AM
tanman350z's Avatar
tanman350z
Default I love this site
I have the same prob and did a specific search on here. Apparently its a common prob with our Z's. A guy on here took it ot the dealer & it turned out to be 2 sensors that needed replacing. I just found the answer to your same question tonight and I hope I wasnt too vague with my answer. Good luck
Old Oct 11, 2008 | 05:56 AM
MongooseZ31's Avatar
MongooseZ31
I have a similar problem. When Im filling up, sometime I cant put more then 1/2 to 3/4 of a tank of gas in. I Z's come with a 20 1/8 gal tank, the most I have ever gotten in my tank was 10 gal. The gauge works fine though. When I'm filling up, the pump stops like im full and i can stand there and "click" all day and it appears to be full.
Old Oct 11, 2008 | 07:13 AM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
there is a tsb out for your problem its a small valve in the filler tube that closes too quick. The parts are like $12 and it take about a hour to install.
Old Oct 12, 2008 | 04:32 AM
inittab's Avatar
inittab
I had the same problem. They replaced both sending units. It took them several tried to figure out the problem. There is a main tank and a spare. each has a sending unit.
Old Oct 12, 2008 | 10:38 AM
JonnyB504's Avatar
JonnyB504
MIne does the same excat thing....I allways get it to work though. You just have to hold the gas trigger like half way and sometimes turn the pump to the left or right and angle it.....its a bit aggervating at times but it works lol.
liqalu04
Jan 2, 2022 12:58 PM
lolwatbro
Oct 9, 2021 04:58 AM
350Z_Al
Oct 29, 2020 07:44 PM
Vigman
Nov 17, 2015 04:34 AM
