Any 08 Transmission Issues?
Old Feb 18, 2011 | 10:01 PM
  #121
r_seng's Avatar
r_seng
Only problems with the HR transmissions that I'm aware of is with the internal slave cylinder.
Old Feb 22, 2011 | 05:46 AM
  #122
dd_Z33's Avatar
dd_Z33
I have an 08 as well. Dropped it off yesterday because it was doing the same noise as chi warriors. I still have warranty so hopefully a new transmission is on the way.
Old Feb 22, 2011 | 09:38 AM
  #123
PrimeX's Avatar
PrimeX
Read through this thread since my clutch is mushy and pretty much sticking to the floor. Taking it in today. I only have 17,000 miles on it too. PRAYING I don't need a new clutch this soon.
Old Feb 23, 2011 | 08:23 AM
  #124
PrimeX's Avatar
PrimeX
Just got confirmation that I need a new slave and master cylinder. So glad I don't need a new clutch right now.
Also, it's being covered under warranty. Awesome news!
Old Feb 23, 2011 | 09:30 AM
  #125
ace32x's Avatar
ace32x
nice! wish mine was XD
Old Feb 23, 2011 | 05:49 PM
  #126
dd_Z33's Avatar
dd_Z33
Good news got that transmission replaced under warranty! My baby is nice and quiet. I can actually hear my tires now lol and that sweet lil growl. How many of yall have had issues with your second transmission?
Old Feb 24, 2011 | 06:33 PM
  #127
NoQuestionZ's Avatar
NoQuestionZ
My Z is at the dealer right now in process of getting a new trans. I'm hoping its night and day difference.. No grind for sure and hopefully butter smooth shifts
Old Mar 1, 2011 | 04:44 PM
  #128
NoQuestionZ
Update a week late...
New trans, clutch, flywheel and labor on Nissan's dime. Gotta love warranties--while they last anyway....
Old Mar 2, 2011 | 07:13 AM
  #129
dd_Z33's Avatar
dd_Z33
Awsome whynot. I've put 300 miles and still no problems. But now I think one of my rear struts is bad. Ugh the problems of buying a used car.
Old Mar 2, 2011 | 08:09 AM
  #130
08sleeperz's Avatar
08sleeperz
Wish it was that easy. I've been fighting with nissan for over a month for a new slave and I still have my 3yr/36k. They are blaming my problem on my pressure plate and say that's not covered. My clutch is fine but its def wearing more with the messed up slave. Hopefully I get what I need on nissans dime eventually.
Old Mar 2, 2011 | 11:32 AM
  #131
NoQuestionZ
Where are you located?
That sucks man, I just went in 2x for the same thing and they got it all in there in in about 3 days, then installed in 1 day and some change
Old Mar 2, 2011 | 12:03 PM
  #132
08sleeperz's Avatar
08sleeperz
Well, I actually made some progress today. Just spoke with the service manager and he said he's gonna throw in a new clutch for me. I still think I have a slave issue but its fine with me if they wanna give me a complimentary clutch.
Old Mar 3, 2011 | 05:50 AM
  #133
PrimeX's Avatar
PrimeX
Congrats sleeperz! It's about time one of those dealerships finally did something for you!
Old Mar 3, 2011 | 08:21 AM
  #134
08sleeperz's Avatar
08sleeperz
Thanks PrimeX. It took about 2 months, 3 dealerships and countless trips. I hope they replace the slave while they're in there too.
Old Mar 6, 2011 | 03:22 PM
  #135
PeterSellers's Avatar
PeterSellers
Would you all say that shifting this car, especially from 1st to 2nd, is kind of a delicate procedure?
When I'm driving slowly just cruising around, the shift from 1st to 2nd is extremely clunky, unless I give it a little extra time between the shift. I kind of have to give it just the lightest amount of force until i feel it go into gear, otherwise I get a little bit of resistance with some clunkiness (I wouldn't exactly call it a grind though). When I'm driving it hard and redlining it pretty much just goes in like I would expect it to, no issues there.
I've had my transmission replaced 3 times (the most recent was just a few weeks ago) and all of the transmissions I had did this.
I talked to the tech at the dealership and he said it was normal. Something about having large beefy gears in the trans just makes it a clunky affair. I'm used to driving hondas and I feel they are much smoother, but I guess all the moving parts in a honda transmission are all smaller so there should probably be less force required. I'm not sure if the tech was just BS'ing or not, I suppose what he was saying made sense.
Old Mar 15, 2011 | 11:37 AM
  #136
yamahaman88's Avatar
yamahaman88
Default Grrr
This is the SAME exact noise i got. This is the "whine" and best video I could find to explain. Clutch IN no noise. Let the clutch OUT, walked away from the dealership. Other than that noise, the transmission, clutch and car are totally fine. This is what's turning me away from buying a mint 2007 with 50k miles. IDK what to do
Old Mar 23, 2011 | 07:43 PM
  #137
Darknight43's Avatar
Darknight43
mines doing that exact noise too. I think its the input shaft bearing thats bad my z got 38k, going to take it to nissan hopefully its still under warranty. Bought it used.
Old Mar 23, 2011 | 08:18 PM
  #138
nyZ_nick's Avatar
nyZ_nick
My z makes that noise mostly after a cold start or after i drive it really hard. I was told it could be the throw out bearing. Other than that my car runs fine. I realized all Z's are noisy so I wouldnt worry much about it
Old Mar 25, 2011 | 07:29 AM
  #139
PeterSellers
That noise in yamahaman's video is perfectly normal (i think its the flywheel actually). If you have a bad input shaft bearing it will make more of a high pitched whine that sounds similar to a supercharger and increases in loudness as you rev up the car in neutral (without touching the clutch).
I've already had my trans replaced once because of it, and now 6 months later I think the new trans is starting to do it again
Old Mar 25, 2011 | 08:32 AM
  #140
Kuhan's Avatar
Kuhan
A few guys are saying the same thing.
Like I said before, f*ck it. Wait until before 5yr/60,000 mile warranty expires and get it done if needed.
*Don't fix if it ain't broken*
