Any 08 Transmission Issues?
Old Oct 19, 2008 | 09:12 AM
Chi-TownWarrior's Avatar
Chi-TownWarrior
Default Any 08 Transmission Issues?
Anyone with an 08 6mt that is experiencing a whining noise coming from the trans? A few guys here on base have 08 6mts that don't whine. I searched and found nothing with the 08. I have 6100 miles and have been wondering about this, and now It's a concern because I can't seem to find anyone else with an 08 and the whining noise, nor any info on it.
Old Oct 19, 2008 | 09:22 AM
ZPHILE's Avatar
ZPHILE
Not here. Got ~28K on my '08 6MT (I know - lots of miles - I love driving my car) and no trans issues. Hope whatever you got can be solved/fixed easy!
GL
H.
Old Oct 19, 2008 | 10:40 AM
kramykram's Avatar
kramykram
yeah sorry man. no problems with my 08 either. take it to the dealership and have them check it. things do go wrong on new cars. look at the oil consumption problems on the 06's
Old Oct 19, 2008 | 03:53 PM
luckydog827's Avatar
luckydog827
yes its normal to whine a little after break in, dont worry its all good
Old Oct 19, 2008 | 04:02 PM
350ZPK's Avatar
350ZPK
Normal.
You should sign up to chicagoz.com
Old Oct 19, 2008 | 05:00 PM
FastZ33's Avatar
FastZ33
13k on a 08 6mt, only whinning noise i hear is from the rear diff
Old Oct 19, 2008 | 05:50 PM
Chi-TownWarrior
I know its the trans, because when I hit the clutch the whine goes away
Old Oct 19, 2008 | 05:55 PM
FastZ33's Avatar
FastZ33
u sure its not jus the flywheel chatter?
Old Oct 19, 2008 | 05:56 PM
Chi-TownWarrior
I'll make a video
Old Oct 19, 2008 | 06:07 PM
red_magic2000's Avatar
red_magic2000
Only compliant with my 08 trans is the "clank" sound it makes when I shift. The mt on the Z is not its strong point. Still can't get the thing to shift smoothly. When I drive my buddy's RX8 the trans feels so good and shifts really nice.
Old Oct 19, 2008 | 06:55 PM
Chi-TownWarrior
I have the same problem. I can shift my friends evo smooth, my neighbors mini, and my old eclipse just fine, but in the Z i feel like a noob
Old Oct 21, 2008 | 10:54 AM
zettahertz's Avatar
zettahertz
Whining sound? I think i have that in first or second gear when I speed up to like 20mph then let go of gas (engine braking). Isn't this normal? The OEM flywheel/throwout bearing noise is more of a whirring sound when at neutral and standstill with clutch disengaged.
Old Oct 21, 2008 | 11:00 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
No issues here either. The only thing but I think its common, is 2nd gear is a bit hard to get into, and feels like I am grinding something sometimes, but other than that it has been fine.
Old Oct 21, 2008 | 12:20 PM
KGsZ's Avatar
KGsZ
I have that whinning sound too in 1st and 2nd gear. is that what your talking about OP??
Also I can't always shift smoothly too. Every other car i drive i do good.
Old Oct 21, 2008 | 03:59 PM
Justin@IOS's Avatar
Justin@IOS
IOS Performance
Have you guys checked with your local dealer yet? If you have a good writer/tech combo they should be able to check out the car rather quickly and let you know if something isn't quite normal. If you don't trust them, maybe look into driving a new car demo and see how that compares to yours. Or meet up with another local Z owner?
Oh and if you think the transmissions are loud now, DO NOT get an aftermarket flywheel. You'll be hating life.
Old Oct 21, 2008 | 08:59 PM
KGsZ's Avatar
KGsZ
Yeah I took it to the dealer a couple weeks ago but they said its normal and that these transmissions get very loud as it breaks in.
My friend has an 06 with an aftermarket clutch/flywheel (forgot what brand) and it is VERY LOUD. Sounds like its about to break down. So ima try to stick with the stock clutch/flywheel until I really have to change it.
Old Oct 22, 2008 | 05:14 PM
kramerbuccs24's Avatar
kramerbuccs24
That sounds like a clutch throw-out bearing to me. I'm getting mine replaced on Friday under an extended warrantee. Unless it's just the flywheel and you're not used to it...
Old Oct 22, 2008 | 07:02 PM
Chi-TownWarrior
Here is what I'm talking about...I did this like 2 min ago
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://s146.photobucket.com/flash/player.swf?file=http://vid146.photobucket.com/albums/r249/banksdrew/MyCarVideo002.flv"></embed>
Old Oct 23, 2008 | 03:22 AM
SnakeBitten's Avatar
SnakeBitten
^^No sound dude. Checked and rechecked my computer and I play other stuff fine except this video....
Old Oct 23, 2008 | 04:26 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
I have sound just fine with his. Mine sounds similar to his.
