different problem with window...
Old Oct 23, 2008 | 09:10 PM
JonnyRod's Avatar
JonnyRod
Default different problem with window...
Im having a unique problem with both of my windows. The windows goes up and down fine, with and without the auto function, and with or without the door closed. But once the key is turned off, as soon as i open my door to get out of the car, the window rolls ALL the way back down. I tried the reset procedure plenty of times but its not working. It went bad the same exact time my passenger window motor took a crap too. Any ideas???
Old Oct 23, 2008 | 10:08 PM
JonnyRod's Avatar
JonnyRod
i hope someone has an answer... i cant make it to the dealership anytime soon!
Old Oct 24, 2008 | 06:30 AM
JonnyRod's Avatar
JonnyRod
bump
Old Oct 24, 2008 | 02:23 PM
JonnyRod's Avatar
JonnyRod
someone mentioned resetting the keyfob...ring a bell for anyone?
Old Oct 24, 2008 | 08:38 PM
JonnyRod's Avatar
JonnyRod
ill pay somebody to figure out this problem for me! lol
Old Oct 24, 2008 | 08:42 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
it sounds like the motor reset procedure have you pulled off your door pannel and done it?
Old Oct 25, 2008 | 02:30 AM
JonnyRod's Avatar
JonnyRod
ya as i mentioned in my initial post, ive tried the reset procedure many times...nothing. i think its because its a different problem. it only happens when my key is OFF and when i open the door, BOTH windows will roll ALL the way down at the same exact time...as if im holding the unlock button on my keyfob
Old Oct 25, 2008 | 09:59 AM
JonnyRod's Avatar
JonnyRod
i left my battery unhooked for all of last night (about 12 hours) and it didnt change anything. im completey stumped
Old Oct 25, 2008 | 11:50 AM
JonnyRod's Avatar
JonnyRod
just checked all fuses in all three panels...everything is good
Old Oct 26, 2008 | 09:41 AM
JonnyRod's Avatar
JonnyRod
sunday bump
Old Nov 15, 2008 | 12:56 PM
Dennis Passmore's Avatar
Dennis Passmore
Have you checked the drivers side door lock on the outside. Someone may have stuck something in there while trying to open the car. If you insert your key and try to unlock the car and if you leave there it for more than two seconds then both windows will automatically go down.
Old Dec 14, 2008 | 07:57 AM
st8king's Avatar
st8king
This just started happening to me too yesterday was hoping to find a cheap solution before I took it to the dealership tomorrow. I will let you know what I find out.
Old Dec 15, 2008 | 06:05 PM
st8king's Avatar
st8king
O.K. problem fixed. The dealership found that the connection on the window micro switch inside the door panel had come loose and had corrosion in it. They cleaned it up and reconnected and as is well.
Rich
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
