Post here only if you have had your TRANNY replaced.
Old Apr 25, 2004 | 03:01 PM
  #261
Pit Bull's Avatar
Pit Bull
Road and track abuse a car that would never happen
Old Apr 28, 2004 | 07:51 AM
  #262
ganz's Avatar
ganz
3rd Gear Grind @ High RPM (upshift 2->3 or downshift 4->3)
Vin#5105
Tranny Replaced 4/26/04 @ 29K Miles
No more chatter (clutch in/out). All gears are smooth... for now.
Old Apr 28, 2004 | 09:09 AM
  #263
Z33Frog's Avatar
Z33Frog
Tranny just replaced yesterday, 4/28/04 @ 2600 miles.
New tranny shifts better into 2nd, but now 1st and 5th are much worse. Loud gear whine at all speeds is still there too. I'm gonna give it 200 miles to break in and pray for improvements...POS.
Old Apr 28, 2004 | 01:32 PM
  #264
pulpz2's Avatar
pulpz2
So what constitutes abuse?
Poor technique like riding the clutch?
Or driving hard like high rpm shifts, launches, aggressive downshifting? Basically I drive my Z the same way it's driven in the "Run" hehe
Old Apr 28, 2004 | 02:42 PM
  #265
Pit Bull's Avatar
Pit Bull
Let me define - abuse by car magizine geek, is when you get to go out into the parking lot get into a 350Z that does not belong to you and drive the **** out of it, knowing that you are doing this for the good of your readers. You know, what we all would like to do I imagine that these Z's are driven harder then I drive mine since if I screw mine up I have to pay for it, plus I am in it with this Z for the long run not 12 months. JMHO
Old Apr 29, 2004 | 05:12 AM
  #266
twodown's Avatar
twodown
Thumbs down Replaced 6mt in G35 Sedan
1st tranny shifted very hard into 2nd gear when cold, and when warm would grind. The new tranny is not much better. I can feel catch going into 2nd and 3rd gear. It is only a matter of time befor this one goes south. 1st tranny replaced on or about 2/15/04 w/6500 mi. on a 03 G35 sedan
Old Apr 30, 2004 | 11:28 AM
  #267
VR3's Avatar
VR3
What does the dealer do with the tranny after it's been replaced? send it back to japan to repair..or scrape it…
Old Apr 30, 2004 | 11:44 AM
  #268
Thaddeus's Avatar
Thaddeus
When mine was replaced in December of '03 I was told the trans was to be sent to NNA. I was also told someone wanted to look at it.
Old May 2, 2004 | 10:27 AM
  #269
asdlasdflkasdfj's Avatar
asdlasdflkasdfj
wow .. i'm buying a 350z now :roll: GOOD GAME SHITTY TRANNY :P
oh wait - i have a bimmer ... that's right i still have another 130K miles before i should start worrying about replacing major parts
Old May 2, 2004 | 10:44 PM
  #270
Fishey's Avatar
Fishey
Are the G35 owners having the same problems.. (This seems to be a HUGE PROBLEM!)
Old May 3, 2004 | 09:14 AM
  #271
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
nobody cares...
Old May 3, 2004 | 09:47 AM
  #272
pulpz2's Avatar
pulpz2
Originally posted by BriGuyMax
nobody cares...
Whata shmuck. He created an account just so he could make that post.
He probably drives a 325 or Z3.
Old May 3, 2004 | 03:49 PM
  #273
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
nah...probably an old 318i hatch....
Old May 4, 2004 | 07:58 PM
  #274
Vish's Avatar
Vish
on the new tranny when accelerating in 1st (not under hard acceleration) it makes an odd whine. Also shifting into 1st and 5th can be a little hard.
Old May 12, 2004 | 07:54 AM
  #275
py350z's Avatar
py350z
New tranny @16,700 at Mossy Nissan 05/12/2004. Didn't realize so many ppl were having this problem.
Old May 12, 2004 | 10:15 AM
  #276
dnguyent's Avatar
dnguyent
Bimmers are nice cars. Unfortunately, they attract people like asdlasdl...similar to how bug zappers work.
My 08 tranny installed 6000 miles ago seems to be holding up well. Fast shifting is still hard, and so is downshifting from 6th to 4th (to pass cars on two-lane roads). I have to shift in sequence because it's a lot smoother even if I gears just tomakes me kind of wish Nissan offered a SMG type transmission...then again, that could be curse if Nissan botches that up too.
The clutch/throwout bearing/transmission noise is still present, but the dealership says it's normal even though I noticed the tech looked quite puzzled while checking the underside of my car.
The G35's must be having similar problems...I can't imagine why it wouldn't?!?!?!?
Old May 12, 2004 | 03:37 PM
  #277
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
The noise you are hearing is completely normal. Larger cut gears and heavy duty bearings make noise....that's the price we pay for having a strong transmission.
In fact, I haven't heard of anyone busting a 350Z trans yet...and some guys are running near 500whp. Before anyone says it....having gears grind is NOT "busting" the trans...it's a synchronizer issue...not a trasmission strength issue. Shredding gears, and not being able to drive the car is a strength issue
Go listen to any sports car that has stock or near stock exhaust idle. (aftermarket exhaust will drone it out) You'll hear bearing noise in many many sports cars. My buddies C5 vette has it...and my other buddies E36 M3 has it MUCH worse than my Z.
Old May 13, 2004 | 05:29 AM
  #278
pulpz2's Avatar
pulpz2
I have to agree. Unless the throwout bearing is bad but I've only heard one or two instances of this happing on the Z.
Old May 14, 2004 | 02:28 PM
  #279
Farren's Avatar
Farren
The original 6 speed transmission was part number -CD000. The latest one is -CD008 which means there have been 8 changes to the transmission since it first came out! The latest update also includes a revised clutch pedal assembly. I dont see how a Nissan dealer can give you a hard time about transmission abuse when Nissan keeps updating the transmission in an obvious attempt to improve on the original design!
Old May 14, 2004 | 02:48 PM
  #280
pulpz2's Avatar
pulpz2
you have to keep in mind that in the manufacturing world small changes (regardless of mechanical significance) can necessitate a revision. Who know if eight revs is typical for a new tranny design or not.
