Post here only if you have had your TRANNY replaced.
Old May 14, 2004 | 02:53 PM
  #281
Pit Bull's Avatar
Pit Bull
I had a Cummmins turbo diesel and they revised the lift pump 15 times in 6 years and they still kept failing
Old May 14, 2004 | 09:46 PM
  #282
joenismo's Avatar
joenismo
I had mine replace about one month ago with version 8. Now when shifting hard at the redline I can't get it to go into 2nd gear. I don't even get a chance to release the clutch pedal. I just pull through from 1st to 2nd and grind but won't even go into 2nd. Dealership told me no warranty on this new tranny because I used the tilton setup. So now what?
Old May 15, 2004 | 05:50 AM
  #283
pulpz2's Avatar
pulpz2
what is the tilton setup?
Old May 15, 2004 | 08:56 AM
  #284
joenismo's Avatar
joenismo
It is a lightweight clutch and flywheel package.
Old May 15, 2004 | 10:37 AM
  #285
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Call Nissan North American and *****....they'll take care of you.
Old May 15, 2004 | 06:59 PM
  #286
conquestcar's Avatar
conquestcar
Vin last 3 digits # 313 - Transmission replaced mid May '04 at 18k miles at Maroone Nissan Miami, Florida.
Grinded into 3th when shifting quick. Won't grind if you really baby it which is not the reason why people buy a "performance" car. So far this is my 1 replace and seems to be ok. Have to give it more shifts to be certain. Fingers crossed. I have lost all confidence in the design, quality and most of all the trust in Nissan and their dealer network. Sad that this fine Japanese car company is now owned by French Renault. Need I say more?
Old May 15, 2004 | 09:17 PM
  #287
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Renault only owns 43% of Nissan....
Futhermore...you have one trans go bad, they replace it UNDER WARRANTY and now you've "lost all faith"??
I don't think that people realize that when you buy a first model year of a car....chances are it WILL have things wrong with it. This is true for cars from ANY car manufacturer in the world.
Old May 15, 2004 | 10:23 PM
  #288
pulpz2's Avatar
pulpz2
Definitely true.
Old May 18, 2004 | 07:58 AM
  #289
GSRto350Z's Avatar
GSRto350Z
Had mine replaced @ 34,000K. When they replaced my Transmission they had to also replace part of the clutch. The new Transmission is great.
Old May 19, 2004 | 01:41 PM
  #290
zpeed350's Avatar
zpeed350
2003 350Z - VIN 4,2xx
Tranny replaced at 16,500 miles on 5/10/2004.
Replaced with:
Transmission: 32010-CD008
Disc Assy-Clutch: 30100-CD019
Pedal Assy Clutch: 46503-CD010
Rod Assy Push: 306310CD000
New setup is excellent after a week. No grinding at all. The only difference is the catch point of the clutch is higher from the floor than the one that came from the factory. Thank you Nissan!
Old May 19, 2004 | 03:01 PM
  #291
Bini2's Avatar
Bini2
Tranny 1 replaced 4/04
Tranny 2 (Tranny Bad from the get go) will be replaced 06/04
Old May 20, 2004 | 10:47 AM
  #292
Clos's Avatar
Clos
Default tranny replaced
had mine replaced at 13k for a third gear grind. now it feels very different. like learning my gear placement all over again.
Old May 20, 2004 | 02:26 PM
  #293
350Zum's Avatar
350Zum
Default Auto tranny ?
I didn't read ALL the posts - just most of them,
but I didn't here anything about the auto tranny.
Has anyone had any problems with their auto?
Old May 20, 2004 | 06:10 PM
  #294
350trackz's Avatar
350trackz
Replaced ...
Monday May 16th, 2004
12,000 miles on the odometer
New tranny (008 version)
Clutch Pedal Assembly
Old May 20, 2004 | 07:32 PM
  #295
Pit Bull's Avatar
Pit Bull
You guys that are having these transmissions replaced. Could you discribe the problem. Are these trans obvious about having a problem or is this just a speed shifting problem? More detail would really help.
Old May 20, 2004 | 09:43 PM
  #296
CAR2's Avatar
CAR2
Mine is being replaced as I speak....23,000 Kms (which seems to be a magic number (14000 to 16000 miles). Delivered March 03. Fifth gear went - crunched if you changed too fast- definitly a synchro problem. Nissan have been good free car while it has been done.
Old May 21, 2004 | 06:00 AM
  #297
350trackz's Avatar
350trackz
Hey there killer (recently seperated Marine here).
My issue slowly showed itself. The 3rd gear grind. If I granny shifted and gave the tranny plenty of time to disengage, it would go real smooth. Problem is, that is not normal shifting as there was a large pause while shifting. ?If i was shifting hard in a race, I would be lucky to hit 3rd gear ... it would grind. If I shifted normal with no pause, it would catch about half the time. I just got tired of it, put together my list of needed fixes and dropped the car off for a week.
Old May 21, 2004 | 06:24 AM
  #298
dimitri's Avatar
dimitri
Well i HAVE
Old May 21, 2004 | 06:29 AM
  #299
dimitri's Avatar
dimitri
well what i have is 2004 track.... built in 7/03 .. i took it to the dealer and they told me this is normal.(nothchiness in second gear no grind though also 1st gear always seems hard to put in ...also seems that you can hear all the mechanical parts it the transmission when shifting gears )Does this seem normal to you guys ?
Old May 21, 2004 | 06:35 AM
  #300
350trackz's Avatar
350trackz
Well, normal yes ... but normal for the transmissions that get replaced It is not supposed to be that way.
