Brakes don't work after bleeding
Old Nov 20, 2008 | 06:10 PM
i<3myZ's Avatar
i<3myZ
Default Brakes don't work after bleeding
so i changed out my brake fluid today and i'm pretty sure i did it properly. after changing out the fluids i took it for a test spin down the street and realized my brakes didnt work. i thought i might have got some brake fluid on the rotor so i sprayed it with a generous amount of degreaser and let it sit about 10 ten minutes but got the same result. i'm thinkin there are air bubbles inside because even when starting the car and not moving, the brakes go all the way down without any resistance. any suggestions would be great.
Old Nov 20, 2008 | 07:04 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
Did you close all of your bleeder valves? Is your master cylineder full?
Old Nov 20, 2008 | 07:05 PM
glowz825's Avatar
glowz825
AIR BUBBLES!
Old Nov 20, 2008 | 07:22 PM
JETPILOT's Avatar
JETPILOT
I don't understand why after bleeding people don't get in their car while it's still o nthe jack stands and start it and press on the brake pedal to feel if it's firm or not before putting the car back together and driving it.
Old Nov 20, 2008 | 07:31 PM
TreeFiddyZee
Do WHAAAAT!?
Adrenaline junkie?
Old Nov 21, 2008 | 07:38 AM
WTX350Z's Avatar
WTX350Z
+1...even though I've forgotten to check prior to driving once...but I was 17...and that's my excuse! That garage door at the dealership wasn't ever the same...but it matched the rest of em after that so no worries.
Air is the enemy of brakes. did you let it go completely dry? (the MC) if so the ABS unit has air in it. good luck. that thing is kinda a PITA to bleed.
Old Nov 21, 2008 | 11:17 AM
i<3myZ's Avatar
i<3myZ
closed the bleeder valves all the way and master cylinder is full..
Old Nov 21, 2008 | 11:59 AM
350Zdj's Avatar
350Zdj
bleed each side 10x.
Old Nov 21, 2008 | 01:46 PM
i<3myZ's Avatar
i<3myZ
jesus, didn't think it'd be so tedious. how much does it usually cost to get it done professionally?
Old Nov 21, 2008 | 02:35 PM
thekinn's Avatar
thekinn
Let us know. I'm curious to know how much I'm saving by doing it myself.
Old Nov 21, 2008 | 04:43 PM
TreeFiddyZee
Do WHAAAAT!?
I'm thinkin' millions!
Old Nov 21, 2008 | 06:01 PM
i<3myZ's Avatar
i<3myZ
Old Nov 21, 2008 | 06:06 PM
Russ@Z1's Avatar
Russ@Z1
with my bleeders open and connected to a tube that's sunk in brake fluid, I tapped the calipers to shake out all the air bubbles that I could. Bleeding is a pain. Especially if you have the brembos.
Old Nov 25, 2008 | 03:37 PM
i<3myZ's Avatar
i<3myZ
my vdc and slip lights won't turn off either. whats up with that?
Old Nov 25, 2008 | 04:21 PM
Barzten1's Avatar
Barzten1
Im having issues bleeding my clutch. It seems like its good them gets mushy after a couple days. Fluid isnt leaking
Old Nov 26, 2008 | 04:10 AM
Z04's Avatar
Z04
that happens when you got people that think they know what they are doing but in reality have no clue.
Chris350z03
Oct 8, 2023 07:19 PM
JjL
East Canada
Jun 12, 2019 03:04 AM
SonnyWu
Nov 24, 2015 08:19 PM
Vigman
Nov 17, 2015 04:34 AM
Shane86
Sep 17, 2015 05:33 PM
