Track rotor replacement question
Old Aug 20, 2003 | 04:06 AM
Jewelz350's Avatar
Jewelz350
Default Track rotor replacement question
Replacing the rotors and I'm trying to think it through before I start.
With the Brembo's, when you unbolt the calipers, do you take the line off the caliper, or unbolt the junction block where the solid (hard) line and flexible line meet?
Also, anyone interested in the new Brembo slotted rotors (FS00097), I got mine at TireRack for $373. That was the best price I found.
Old Aug 20, 2003 | 01:51 PM
EnthuZ's Avatar
EnthuZ
Joyia, I'm guessing, but you shouldn't need to open the brake line. If you can't move the caliper far enough out of the way to remove the disk, you MIGHT have to remove one of the junction block mounting bolts. Then again, might be a good time for some stainless brake lines!
I'm curious.......How do your stock pads look after Gingerman?
Old Aug 21, 2003 | 03:54 AM
Jewelz350's Avatar
Jewelz350
Bruce, ask me again after this weekend. The rotors arrived last night and I won't have a chance to take everything apart until this weekend. I'm also waiting on a set of Hawk's to arrive as well.
Hey, you forgot to tell me what a PIA these wheels are to get clean!
Old Aug 21, 2003 | 05:08 AM
westpak's Avatar
westpak
SFZCC
To replace rotors all you need to do is remove the two bolts that hold the caliper to the car, that is it not need to mess with the lines. The front rotors are then lose and come right off, I have not done the rears but I have heard it is the same just use some force to remove rotors.
Old Aug 26, 2003 | 10:38 PM
Kansai's Avatar
Kansai
Dont forget to to spread out the pads inside the caliper to push back the pistons! If you dont do that, the new rotors will not fit into the caliper.
Let me know if you need any photos which I can email to you.
Old Aug 27, 2003 | 04:24 AM
Jewelz350's Avatar
Jewelz350
Thanks all for the replies. All went well with the install. Only 'issue' was breaking loose the nut on the back of the caliper. It was awkward to get to (and torqued so tight) so I got on the ground and pushed with my foot to break it.
etkms
Jun 19, 2022 06:30 PM
Vigman
Nov 17, 2015 04:34 AM
SanmarinoZ
Oct 21, 2015 10:04 AM
Suffolk350z
Sep 13, 2015 02:43 PM
Alex Tappin
Sep 9, 2015 08:18 PM
