PLEASE HELP IM TIRED OF THE RUN AROUND!!!
Old Nov 24, 2008 | 06:11 PM
Antronig's Avatar
Antronig
Default PLEASE HELP IM TIRED OF THE RUN AROUND!!!
Hello I have a 2005 350z and I had a small fender bender in the rain which I have fixed all the damage for and settled without icbc. The vehicle is in excellent shape except for the airbags have deployed and have activated a failsafe which doesn’t allow the vehicle to restart, it wont even turn over and the car is stuck in manual drive and key is stuck in the ignition due to being stuck in drive.
I have the car located in my garage and have narrowed the problem down to either the ecu needs to be reset, wiring harness wired < due to possiblilty of it melting in order to keep the engine from restarting> or even the airbag modual needs to be reset or a combination of these, a mechanic would be able to look at it and tell especially if you work in a body shop and have done this before, which is usually the case.
thank you
Old Nov 25, 2008 | 10:22 AM
nothix's Avatar
nothix
maybe try this?
How to Set Diagnostic Test Mode II (Self-diagnostic Results)
1. Confirm that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
2. Repeat the following procedure quickly five times within 5 seconds.
a. Fully depress the accelerator pedal.
b. Fully release the accelerator pedal.
3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the MIL starts
blinking.
4. Fully release the accelerator pedal.
ECM has entered to Diagnostic Test Mode II (Self-diagnostic results).
How to Erase Diagnostic Test Mode II (Self-diagnostic Results)
1. Set ECM in Diagnostic Test Mode II (Self-diagnostic results). Refer to EC-73, "How to Set Diagnostic Test
Mode II (Self-diagnostic Results)" .
2. Fully depress the accelerator pedal and keep it for more than 10 seconds.
The emission-related diagnostic information has been erased from the backup memory in the ECM.
3. Fully release the accelerator pedal, and confirm the DTC 0000 is displayed.
Old Nov 25, 2008 | 05:51 PM
Antronig's Avatar
Antronig
just got update aparently it wont start cause its stuck in manual drive 1 and shifter goes up and down like + and - but wont move over i need it in neutral or park to start. The damn key is stuck inside i tried the shift lock to no avail any ideas?
