Transmission won't shift into any gear when cold
Old Dec 3, 2008 | 05:46 AM
hackermb's Avatar
hackermb
Default Transmission won't shift into any gear when cold
I know there were a couple of threads talking about this but none of them really answered why this happens or really how to fix it. When its cold outside around 32 deg F the transmission will not shift into any gear and by will not shift I mean I can put all my weight into the shifter and it will not go into gear. Does anyone know why this happens on a 2007 Base. If so does anyone have any suggestions on how to fix the problem besides just warming the car up. I have had manual RSX and Eclipse and never had this problem obviously these are different setups but I just wondering why its so bad on the 350. Thanks for your help.
Old Dec 3, 2008 | 07:55 AM
VO...'s Avatar
VO...
Administrator
Moved...
Old Dec 3, 2008 | 09:06 AM
Chaser720's Avatar
Chaser720
Lemoned Z
The 350z has one of the most reliable transmissions out there so IDK.
Old Dec 3, 2008 | 10:03 AM
drmr9grl's Avatar
drmr9grl
My '04 Base is having problems shifting into 1st and 2nd :0(
Everyday since it started getting cold out its been getting worse and worse...
I'm thinking I need a new transmission soon *sigh*
Anybody have other suggestions??
Old Dec 3, 2008 | 10:38 AM
halcyon901's Avatar
halcyon901
well, OP said that his shifter will not go into gear, which is different from post#4's problem. after the car is warmed up, is it easier to get it thru all the gates?
Old Dec 3, 2008 | 10:49 AM
hackermb's Avatar
hackermb
Yeah once the car gets warmed all is good and it shifts perfectly so Im confused as what the problem could be. I mean its not like its just hard to get it into gear, it will not go into gear at all.
Old Dec 3, 2008 | 01:57 PM
B1nKs's Avatar
B1nKs
That fcking sucks..I'm glad in live in SE Texas now. I hope it doesn't start happening to me and I hope you get the problem solved. Have you taken it to the stealership to ask them about it ?
Old Dec 3, 2008 | 02:48 PM
Tac-M's Avatar
Tac-M
2 things - gear box oil and clutch engagement point.
Other than that your car is just fine, don’t freak out.
quick fix - let it warm up for 5 min
Old Dec 3, 2008 | 02:50 PM
0jiggy0's Avatar
0jiggy0
my car is definetly harder to get into gear, but by no means impossible, maybe time for a fluid change? i dunno if not take it to the dealer.
Old Dec 6, 2008 | 04:26 PM
TheBroberts's Avatar
TheBroberts
I just moved off to school and its about 28-35 in the morning when i leave and its tough to get into first but not impossible, after 30 seconds its good
Old Dec 6, 2008 | 08:02 PM
hackermb's Avatar
hackermb
Ok so something new just happened I left it in gear overnight and now when I start it up with the clutch pushed in it runs for a second, leaving the clutch pushed in then stalls out. Also while doing this I am unable to take it out of first gear. Any suggestions on what the problem is?
Old Dec 6, 2008 | 09:04 PM
I suspect that the problem is the clutch not the transmission. Could be anything from the release bearing to a bad clutch disc.
Old Dec 7, 2008 | 11:36 AM
mberthia's Avatar
mberthia
Looks like the OPs problem is more serious than that. In addition if you let the car warm up for 5 mins, all you are warming up is the engine, not the transmission. You need to drive it in gear for 5 mins which sound like he can't even do...
Old Jan 7, 2009 | 12:14 PM
rotchcrocket04's Avatar
rotchcrocket04
Hey guys, curious on your thoughts because I'm having a similar problem.
Since it got cold I've been having this problem. 2nd and 3rd gear, when they are cold (even after a 5-10min warm up) they upshift relatively normal but would have to have serious force to downshift to. 3rd isn't nearly as bad but 2nd would need to be pulled on. I have an 8 mile drive to work (5 highway)... by about the end of the highway travel, the trans shifts up and down like butter!? I try my hardest to not downshift to either of these gears when they're cold because I know it is definitely not good for it but I'm really trying to figure out what's going on?!
I also changed the trans fluid/rear diff fluid to Redline Synthetic a few months ago.
Thoughts? Thanks in advance guys...
(I posted this in another trans thread but I continued to search and bumped this thread as well. I believe this OP has more similar problems than the other thread)
Old Jan 7, 2009 | 02:35 PM
hackermb's Avatar
hackermb
So the problem with my transmission was actually the clutch master cylinder. I think I heard there was a recall for it but Im not sure. All I know is that they replaced it for free and now everything is fine. Except a little problem with shifting into 1st at idle, around 1k. If I tap the accelerator a little with the clutch pushed in, it goes in perfect if not I have to force it a little. Don't really know what the issue is any ideas?
Old Jan 7, 2009 | 07:33 PM
Thumbs up
lapham3
Oct 7, 2022 03:15 PM
burglapfd
Dec 6, 2020 01:04 PM
sherm
Apr 11, 2020 05:21 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
