Pumpkin Leaking.....What Could Cause this?
Old Dec 3, 2008 | 08:10 PM
Barzten1's Avatar
Barzten1
Default Pumpkin Leaking.....What Could Cause this?
Was under the car and noticed some burnt fluid leaking from top of pumpkin. Didnt smell like nothing and wasn't moist or oily. Never even drive the car hard anymore. What could cause this all of a sudden?
Old Dec 4, 2008 | 07:19 AM
Barzten1's Avatar
Barzten1
bump
Old Dec 4, 2008 | 07:23 AM
z2envy's Avatar
z2envy
Was it black or dark color? I think I have the same problem. It's not moist or anything it's kinda like someone spilt paint on it and it's dried up. Hope someone else knows what this could be from.
06blueZ's Avatar
06blueZ
probably a ruptured rear diff mount...
Old Dec 4, 2008 | 07:37 AM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
could be a rear subframe/diff mount but more likely the vent for the diff has some fluid come out of it and dried on.
Old Dec 4, 2008 | 07:42 AM
My350P's Avatar
My350P
Improperly carved jack-o-lantern.
Old Dec 4, 2008 | 07:43 AM
z2envy's Avatar
z2envy
I'll have to get up under and check to see if it leaked from the vent. I only noticed it after I had the car FI'd.
Old Dec 4, 2008 | 08:56 AM
sfarrah's Avatar
sfarrah
As already mentioned it could be your front diff bushing. Mine blew out from 6500rpm launches at the drag strip. It leaked all down the front of the diff and at first I thought it was the cover leaking. Nissan doesn't sell just the bushing, they only sell the entire subframe. That's when Kuah at SPL decided to make the solid diff bushings.
Hopefully it's just some fluid puking out your drain tube.
Old Dec 4, 2008 | 09:27 AM
z2envy's Avatar
z2envy
From the looks of that pic on SPL site it could be the Rear Diff bushing. At least it's not to expensive.
Old Dec 4, 2008 | 09:40 AM
Motormouth's Avatar
Motormouth
the bushing will visually start sagging if it ruptured (usually on the inside it tears). the center metal portion will not be sitting centered in the middle, it will be sitting lower and the bottom of the rubber seal will be bulging out.
As I said before: if you have an aftermarket LSD, high power or have ever tracked/dragged/drifted your car, your bushing is probably suspect. Yet no one ever checks. This damage so completely compromises the handling of your car it should always be changed if you put in an aftermarket LSD.
the SPL bushing is top notch and beautiful. car feels great after it... best option and inexpensive... but a PITA install.
Old Dec 4, 2008 | 09:56 AM
z2envy's Avatar
z2envy
Think I'm just gonna order it now while I'm at work just to be on safe side. I'm starting to really think mine are blown out.
Old Dec 4, 2008 | 10:21 AM
kuah@splparts.com's Avatar
kuah@splparts.com
Vendor - Former Vendor
If you have not already seen this picture, a ruptured diff mount will create black paint-like streaks on the diff housing:
Old Dec 4, 2008 | 12:31 PM
Motormouth's Avatar
Motormouth
that subframe is upside down as well. no wonder the diff is leaking!
(lol)
Old Dec 4, 2008 | 12:50 PM
lgear080's Avatar
lgear080
Can one of you guys link the purchase page for the solid bushing?
Mine has popped too. Was told by a reliable mechanic that this should
not affect my dd. What do you guys think? I never noticed an issue behind
the wheel before or after it popped.
Old Dec 4, 2008 | 02:08 PM
Motormouth's Avatar
Motormouth
go to SPL's web site? http://www.splparts.com/
click to enter > Z33 > suspension > subframe & diff bushings > SPL PRO solid rear differential bushings 350Z/G35 $119
the REAR is the one that breaks. the front two can also be replaced with a kit on that page.
Old Dec 4, 2008 | 02:11 PM
kuah@splparts.com
LOL
Old Dec 4, 2008 | 04:47 PM
Barzten1's Avatar
Barzten1
Yup thats what it looks like. Is it a cheap or expensive fix? Is it something i can do myself?
Old Dec 4, 2008 | 04:50 PM
surfcity40's Avatar
surfcity40
I'd go with this....can you post a pic of yours that isn't upside down?
Old Dec 4, 2008 | 04:51 PM
Motormouth's Avatar
Motormouth
I installed my bushing package from SPL myself (with a friend, a lift and lots of beer, and eventually a machine shop to press out the old front bushings)
it was very labor and time intensive, but not technically demanding. you need a torque wrench to reattach the axles, driveshaft and front diff bushings and other then that, it takes patience and persistence because the rear bushing does not want to come out.
I did not drop my rear subframe to remove it because... I am lazy and had a lift you need to destroy the rubber portion of the bushing to be able to cut out the bushing. we found a large bore drill to make some access holes, then a hand saw to cut through the metal spindly things on the inside of the bushings (holding the center up) works well. once you get the center & most of the rubber bushing removed (where the diff bolts to) it's a matter of a hacksaw cutting through the outer bushing race which then releases the tension holding it in place and you can take it out. clean up the surface and you are ready to install the new bushing.
*the shops I have seen replacing subframe bushings usually use a blow torch to melt them, and I would do the same if I had dropped the subframe.
the new solid SPL bushing is not 'too' hard to put in, you use a TON of soap and a lil water to lubricate and you basically hammer the everliving hell out of it to get it in. SPL provides a tool so you don't destroy the beautiful anodizing on the bushing but it isn't the greatest tbqh.
I would also recommend you change the two front bushings out as well since you already have it apart.
let me know if that is totally confusing
Old Dec 4, 2008 | 05:09 PM
Barzten1's Avatar
Barzten1
Thanks for the info bro
