Window rolls down automatically
Old Dec 7, 2008 | 07:42 PM
sambo's Avatar
sambo
Default Window rolls down automatically
my pass window rolls down halfway by its self, after i roll it up all the way.
i have to hold the window switch up and press the window lock button to keep it closed full. When u open/close the door the window doesnt auto seal up or down.
will the reset work?
Old Dec 7, 2008 | 08:26 PM
contreja2004's Avatar
contreja2004
my 350z does the same thing whats the problem is it the switch or something else?
Old Dec 7, 2008 | 10:16 PM
Tekwon-V's Avatar
Tekwon-V
when it starts to roll back down on its own, it means that your window lift motor is about to fail. give it another a month or so and it will fail.
you can obviously replace the motor or take it apart and clean it. this usually allows you to squeeze a little bit more life out of them. fyi, i am on my 2nd replacement motor. yay nissan.
start studying how to tear apart the door panel
Old Dec 7, 2008 | 10:22 PM
sambo's Avatar
sambo
makes no sense, nissan is weak. Those motors should be free. Worthless garbage.
Old Dec 8, 2008 | 11:16 AM
lil_shaun's Avatar
lil_shaun
damn i have this same problem, even gets to the point where when i close the door it rolls down sometimes. According to the manual it does that automatically when it senses that something is blocking the window from closing all the way, in my case my tint is slightly peeling at the top of the window so i thought thats the reason, but if this is happening to you as well, not good news...
how much is it to get the motor replaced?
Old Dec 8, 2008 | 12:02 PM
pimpsta's Avatar
pimpsta
I'm on my 3rd motor and it failed again (won't go up or down). My advisor quoted me $320ish for part and labor. Good deal?
Old Dec 9, 2008 | 04:42 AM
Jgrizzle's Avatar
Jgrizzle
Search for the DIY on cleaning the motor. Worst case scenario if you mess it up you have to get a new one anyway. To be honest its not that hard to do and the instructions are pretty good.
Just another alternative. Good winter type project (assuming you have a garage and or live in california)
Old Dec 9, 2008 | 05:01 AM
ny garbage_juice's Avatar
ny garbage_juice
yea welcome to my life...i learned to deal wit it
Old Dec 9, 2008 | 06:57 AM
Slickdvl's Avatar
Slickdvl
I don't believe that the motor is the problem. I had this problem on my maxima. I was able to correct it by resetting the window. The trick was to hold down a button behind the door handle (pull out the control and reach inside the door). Then while holding down that button roll the window down (not auto), then roll the window up (not auto). Let go and you are done.
http://forums.maxima.org/5th-generat...w-problem.html
Old Dec 9, 2008 | 07:10 AM
Slickdvl's Avatar
Slickdvl
https://my350z.com/forum/maintenance...dow-motor.html
FYI, the reset button is the very last pic in that thread
Old Dec 9, 2008 | 09:08 AM
spdtckts's Avatar
spdtckts
i had this same problem i paid out the *** for what i could have done myself. it was my only choice. i was over seas.
Old Dec 9, 2008 | 11:33 AM
Jgrizzle's Avatar
Jgrizzle
Yeah thats the one i was talking about. I was just too lazt to go get it.
Old Dec 21, 2008 | 07:25 PM
contreja2004
i changed the motor already but still have the same problem
Old Dec 21, 2008 | 07:28 PM
sambo's Avatar
sambo
its horrible, i havent messed with my Z yet..havent been driving it lately so ill try the 're-set' procedure.
Nissan should have this issue under recall.
Old Dec 23, 2008 | 11:14 AM
nemesis323's Avatar
nemesis323
where is the reset button on the 350z ??????
Old Dec 23, 2008 | 11:30 AM
Slickdvl's Avatar
Slickdvl
https://my350z.com/forum/showthread....n+window+motor
Last picture
search guys
Old Jan 21, 2009 | 06:39 PM
bp240's Avatar
bp240
thats weird that it would happen on the windows, cuz ive had that problem on my 04 325i and 04 e320, but it was the sunroof not the window
Old Jan 21, 2009 | 06:51 PM
WV350z's Avatar
WV350z
My Z has done it for months..POS!!! i hate ill close the door and go in somewhere come back and its wide open for anyone to get in!!
Old Jan 29, 2009 | 04:06 AM
basicblack@nola's Avatar
basicblack@nola
My 06 did the same thing but was under warranty the dealer said that they had to "reprogram" the window what ever that means but I'V had no trouble since then which was about a month ago.
Old Jan 29, 2009 | 05:30 AM
j.arnaldo's Avatar
j.arnaldo
Motor: $161.00 at PepBoys; $40 for the installation. So far, so good. That's one of the 2 nuisances our beaZts suffer from: That, & the gas latch release thingy. Other than that, My 'O4 Touring Coupe's a dream come true at just the right price--$20,500, with only 13k on it (still with that new car scent!!!). NO overheating, FLAWLESS AT, NO feathering, NO oil-consumption issues, two weeks out of a tankful...That's my baby!
