stalls out when started
Old Dec 26, 2008 | 03:52 PM
fireztx's Avatar
fireztx
Default stalls out when started
Ok guys, 04 manual that stalls out when I rev it up to lets say 5k, when I take my foot off the gas and the revs go down it will go below a thousand (where it idles) and stalls out. When I start the car it fires off and when it comes back to idle it will stall out. I have to hold the gas down for a while to prevent this. whats the deal?
on another note a few times while cold the engine would knock for a while untill it warmed up.. oil pump? something else? I was on royal purple then this started and I went to mobil one which I have now..
Old Dec 26, 2008 | 05:29 PM
phenom92's Avatar
phenom92
As for the oil, Royal Purple is known to cause a knock in the engine, not sure why i would do a search on that. As for the stalling, is the check engine light (CEL) on? Possibly the high idle valve or possibly a PCV valve. could be numerous things but it sounds like a high idle valve.
Old Dec 26, 2008 | 06:26 PM
fireztx's Avatar
fireztx
no engine lights, no real warning. as for the other threads I feel like its a mass air flow sensor issue but who knows
Old Dec 26, 2008 | 09:53 PM
phenom92's Avatar
phenom92
it could be that as well, but that would usually throw a code. how many miles are on the car?
Old Dec 26, 2008 | 10:11 PM
kevincat's Avatar
kevincat
did you reset your ecu or something?
you might need to do a idle relearn
Old Dec 29, 2008 | 09:35 AM
fireztx's Avatar
fireztx
93k miles on the car.. have not done any relearn how would I go about that
sherm
Apr 11, 2020 05:21 PM
3vilbunny
Jul 18, 2017 05:10 PM
Dymsi
Sep 29, 2015 11:32 AM
