I have no gears
Old Jan 1, 2009 | 04:35 PM
markg350's Avatar
markg350
Angry I have no gears
Just got home from the MARINE an took my 03track out for a spin. drove about an hour no problem. On the way home i turned my VDC off an got on it. 1st(about5000RPM) 2nd(5500RPM) an then 3er. IHAD NOTHING all gears r gone. Will not engage any gear.itdident even make a sound just a bunch of free play on the shifter. WHAT HAPPEN????????? THANKS FOR ANY HELP......The pedel feels fine.
Old Jan 1, 2009 | 06:42 PM
The gears are still there. I promise.
Old Jan 1, 2009 | 06:54 PM
*Boose*'s Avatar
*Boose*
I don't know man. The gears may have fallen through the case.
Old Jan 1, 2009 | 06:55 PM
LVZ053's Avatar
LVZ053
I believe you killed your clutch. Do you smell burning clutch?
Old Jan 2, 2009 | 05:07 AM
gyotar's Avatar
gyotar
sounds like a clutch to me...
Old Jan 3, 2009 | 04:11 PM
markg350's Avatar
markg350
no i dident smell nothing or heard anything. so i guess i start looking for a new clutch?
Old Jan 3, 2009 | 04:12 PM
markg350's Avatar
markg350
Angry No gears
Thanks for the help.. i did ent smell anything. the pedal would feel funny if it was the clutch RITE?
Old Jan 4, 2009 | 11:36 AM
No. Peddle feel and clutch to flywheel contact are unrelated.
This is simple troubleshooting for a mechanic to figure out what is and what is not working properly. Take the car to a competent mechanic.
Old Jan 4, 2009 | 11:48 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
when the car is off, if you move the shifter lever, does anything happen? is there any resistance there, or does it just wobble around?
Old Jan 4, 2009 | 01:25 PM
markg350's Avatar
markg350
U got it. the shifter just wobbles around no resistance at all. got a good clutch/flyweel setup u would recomend.if thats what it is. ill try to getto a shop somtime real soon. (cant wait to see how much this will cost) The shops around me have no idea what the hell there doing. i wouldent take my honda to any of them an i hate dealerships but i might not have a choice. once again thanks for all the feed back.
Old Jan 4, 2009 | 01:33 PM
Ask for a shop recommendation in your regional forum.
Old Jan 4, 2009 | 01:50 PM
Z1 Performance
Former Sponsor
hard to say for sure without being there, but sounds alot like the problem I had on my own car over the summer. Good news it's an easy DIY fix if this is indeed the problem
Take the shift **** off and pop off the shifter surround plate with the shifter boot (unplug the a/c module from the back and snap the piece out of place). From there, take out the 4 x 10mm bolts that hole the metal "ring" in place, and the rubber insulator boot and cloth piece will come out. With that out, you'll be able to literally see the ground now. Looking down at where the shifter lever goes, hopefully what you'll find is that the bolt and nut that are used to secure the lever to the shifter mechanism is gone. On my car, they actually came out but were still sitting right in the little 'tunnel', so I was able to fix it quickly. If that turns out to be it, get the car up in the air on jackstands and replace the bolt and nut from underneath - use a bit of threadlock on there and it won't ever come off again.
Good luck, hopefully that's the problem
Old Jan 4, 2009 | 04:25 PM
markg350's Avatar
markg350
hey man THANKS ALOT for all your help. i start start school(to get my CDL classA) tommorw so as soon as i have time i will check that out. Youve been a big help an if i ever need anything for my z ill give u a call or drop a line. once again thanks.
Old Jan 10, 2009 | 10:53 AM
markg350's Avatar
markg350
I wish i couldput pic up but i got the plate of (looking at the groundand that ruber gropment off the transmision hole ) All i see is the ball of the shifter rooling freeley in the transmision like it poped up.
Old Jan 10, 2009 | 11:03 AM
Z1 Performance
Former Sponsor
ok - the shifter lever is held in with a single bolt and nut - IIRC it's 10mm. Is that still attached? Does the shifter have any resistance to it, or does it just wobble around freely
Old Jan 11, 2009 | 08:33 AM
markg350's Avatar
markg350
Default no gears
(note, i do not have the car in the air) but im not seeing any bolt or nut missing(that might be cause its not there) , but the ball of the shifter is just rolling(wobbling) freely in the trans. im jumping back an fourth from the car an shovling 12inches of snow soo i havent give it a hugelook over but thats what im seeing with the car on the ground.NO RESISTANCE AT ALL when moving the shifter around. Do i need to get under the car to see some of this stuff?
Old Jan 11, 2009 | 08:47 AM
Z1 Performance
Former Sponsor
the lever basically sits in a pocket, and there is a single nut/bolt combo that keeps the lever connected to the arm that actually moves the gears. The lever itself doesn't sit "in" the transmission like on, say a T5 type, It might be easier to see it from under the car, so if you get a chance, get it up in the air and maybe snap a pic, and I can help you from there
Or maybe some one has the exploded diagram from the factory service manual they can post? I don't have a copy on my laptop unfortunately
Old Jan 13, 2009 | 07:33 AM
markg350's Avatar
markg350
got photos in an album.
Old Jan 13, 2009 | 12:27 PM
markg350's Avatar
markg350
i didnt know how to put photos up on the fourm soo i put them in an album. check them out]
Old Jan 13, 2009 | 03:24 PM
Z1 Performance
Former Sponsor
you have to take the 3 bolt bracket off as well to be able to see if the bolt I'm talking about is still connected or not
