Speedometer stopped working!!!
Old Jan 22, 2009 | 06:38 AM
specialized5223's Avatar
specialized5223
Default Speedometer stopped working!!!
I ned an inspection today and this is going to make me fail.
I need some help quick. it worked. I disconnected the center consol gauge cluster above the radio and reconnected it, now it doesnt work. i rechecked it, everything is hooked up fine. still doesnt work.
I was thinking maybe this effected the odometer somehow so t needs to be dealer reset...
Old Jan 22, 2009 | 07:17 AM
burner's Avatar
burner
Its probably a fuse. Check them all (under hood too).
Old Jan 22, 2009 | 08:52 AM
Xlr82x's Avatar
Xlr82x
while it is important that your speedo works, I am pretty sure that it wont cause you to fail a safety inspection. Didn't fail my eclipse when the speed sensor went out but then again that was in Missouri so I am not sure how TX is different.. just throwing that out there
Old Jan 22, 2009 | 02:24 PM
specialized5223
already tried to get a inspection and it failed because of it. i thought it mite be a fuse. i'm not good with eletrical ****. i dont even know what a blown fuse looks like.
Old Jan 22, 2009 | 04:48 PM
burner's Avatar
burner
If you are in Killeen and want to come to Austin I can look at it for you.
Old Jan 22, 2009 | 05:28 PM
specialized5223
Here's the kicker, I need an inspectin sticker. I could borrow a friend's gps so i know my speed but i'll get pulled over without an inspection sticker. I have the best luck ever with getting pulled over lol.
i may take you up on that though.
Old Jan 22, 2009 | 05:52 PM
burner's Avatar
burner
2500RPM in 6th is 65MPH....just pop your GPS in that will tell you your speed...let me know
Old Jan 22, 2009 | 06:14 PM
specialized5223
If i come down to buy some parts, i'll give you some notice so we can check it out
_bit
Oct 2, 2015 07:49 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
