06 350z, voided drivetrain warrenty.
Old Jan 26, 2009 | 06:08 PM
FAIRLADYZ_MANnE's Avatar
FAIRLADYZ_MANnE
Default 06 350z, voided drivetrain warrenty.
Ok so the dealership told me that they could not help me with my problem because i had mods done to my car.
They said that something must have fallen into the intake or got sucked up because it sounds like there is something in there and also my spark plug was pushed down.
I was thinking maybe i could use a scope with a light or a magnet, something to see if in fact it is a bolt or something.
I am sure i never let nothing into my motor w/e i did take things off.
I was wondering what tools do i need to take off the head to see whats up.
Old Jan 26, 2009 | 06:57 PM
GrayG35's Avatar
GrayG35
ill be over to help u dismantle the engine on sat if we cant get it fixed by weds or friday
Old Jan 26, 2009 | 07:24 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
They are full of crap. Unless they can prove that the damage was directly related to said mods, then they don't have a legal leg to stand on.
Old Jan 27, 2009 | 03:03 AM
DavesZ#3's Avatar
DavesZ#3
They already have proof. There's something (bolt, nut, washer, etc.) dropped into the engine. They don't come from the factory that way so the only way it could have gotten there was by somebody working on/modifying the car. Those aren't covered under warranty. Read your owners manual and see what's covered - you won't find "stuff dropped into the engine" as something that's covered.
Old Jan 27, 2009 | 03:21 AM
0jiggy0's Avatar
0jiggy0
I dont see how the hell a bolt could have even gotten in there... Unless you dropped something in there when you did your plenum spacer. What is the problem with your car?
Old Jan 27, 2009 | 08:18 AM
krnzzang84's Avatar
krnzzang84
If you drop something into the manifold and if you started the car then GL!!!
Old Jan 27, 2009 | 08:23 AM
blasian's Avatar
blasian
None of my lost bolts never went in the motor
Old Jan 27, 2009 | 08:31 AM
SirSpeedyZ's Avatar
SirSpeedyZ
missing bolts in the motor, you got problems
Old Jan 27, 2009 | 09:27 AM
DavesZ#3's Avatar
DavesZ#3
Look at his mods - MREV2 and MD spacer. Changing out the lower plenum requires removal of the bolts inside the plenum that hold the lower plenium to the intake manifold. Because of the danger of stripping those aluminium blocks, everybody is real careful about overtightening the bolts. It would be real easy to leave once loose enough to vibrate loose and eventually pop out the hole and drop down into the intake.
Old Jan 29, 2009 | 07:36 PM
FAIRLADYZ_MANnE
i know i never lost a bolt anyway, the only way i could have dropped something is when i changed out my intake and intake tube, i havent played with my intake manifold in months. keep that in mind, also
my Question Was what tools do i need to take off the heads, i dont need feedback telling me about the problem i already have.
also Does anyone know of a scope that is small enough to fit into the spark plug hole.
Old Jan 31, 2009 | 02:16 PM
FAIRLADYZ_MANnE
bump, also is there a manual i can buy maybe at the dealer or online?
Old Jan 31, 2009 | 02:56 PM
Spork's Avatar
Spork
I remember my days prior to the Z.. whenever I worked on my vehicles I'd always either end up with too few bolts or one too many.
Never dropped anything in the engines tho.. dunno how that'd happen.
Old Jan 31, 2009 | 03:10 PM
*Boose*'s Avatar
*Boose*
There is something called a borescope that would fit and there's flexible ones for really tight spaces. But the $30,000 price tag probably wouldn't. Maybe there is a much cheaper more conventional one to use.
Old Jan 31, 2009 | 06:43 PM
AstroZombie's Avatar
AstroZombie
just burnt you a copy of mine... PM'ing you now to get your address.
Old Jan 31, 2009 | 07:58 PM
Sleepy79's Avatar
Sleepy79
Ridgid Seesnake
Old Feb 1, 2009 | 02:07 PM
FAIRLADYZ_MANnE
well i brought this 200$ one and it'll find inside of the spark plug hole.
also thanks josh and astrozombie
liqalu04
Jan 2, 2022 12:58 PM
issyz
Jul 2, 2017 03:04 PM
wanderingstuden
Jan 28, 2016 07:03 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
nanotech
Oct 2, 2015 05:02 AM
