Strong vibration 80+mph
Old Feb 6, 2009 | 06:32 AM
eZe323's Avatar
eZe323
Default Strong vibration 80+mph
Hey,
I recently picked up a set of volk sf challenge 19" from a friend. Aside from some minor curb rash, the wheels are perfect. Anyways, while driving to work today the car started to vibrate at around 80mph. I did search the forums, but all I can find are posts about hubcentric rings, I already have a set of these installed, however they are from a G35coupe. Would the fact that the hubcentric ring are from a G35coupe, cause this vibration? Would I need an alignment, (last alignment was done a few months back)? Or is this normal? Well, I was told of some vibration, but did not expect it to be so strong. It felt like i was sitting in a massage vibrating chair, and my mirrors were also vibrating as if I had a huge sub in the back. Has anyone had a similar issue? if so, how'd you go about it?
Don't know if this matters but the car is a 2005 35th anniv. 6mt. My stock wheels were smooth as silk, exaggeration, but much smoother than these.
Thanks,
Old Feb 6, 2009 | 07:07 AM
terrasmak's Avatar
I would check if he had the proper rings, next would be a balance check
Old Feb 6, 2009 | 07:09 AM
LAKERSFAN's Avatar
LAKERSFAN
get your wheels balanced and you'll be good to go.
Old Feb 6, 2009 | 07:53 AM
DavesZ#3's Avatar
DavesZ#3
As long as the rings fit those wheels on the G35, then they should be working fine on the Z. Probably time for a balancing job.
Old Feb 6, 2009 | 07:57 AM
JMS71585's Avatar
JMS71585
Have your tires rebalanced. I put on some Volk GT-7s and experienced vibration at high speeds. Turns out the mechanic didn't do a good job on balancing my tires. Check them out...
Old Feb 6, 2009 | 10:06 AM
Chebosto's Avatar
Chebosto
Originally Posted by CityTireOnline
Tire Balancing problem.
Go to a good shop with top end equipment. Or see if you can find a Hunter Road Force balance, it will do the trick, if not tell you that one of the tires or wheels will not balance due to damage or defect.
http://www.gsp9700.com/
There is a locater on that site as well.
mr.b?
Old Feb 6, 2009 | 10:22 AM
savvy's Avatar
savvy
like everyone else said, wheel balance
Old Feb 6, 2009 | 11:10 AM
eZe323's Avatar
eZe323
Thanks guys, I appreciate your comments, and will go ahead and get the wheels balanced. I honestly thought I'd get flamed for my question, because I actually thought about wheel balancing after I hit "submit."
Old Feb 6, 2009 | 12:15 PM
zSupreme7's Avatar
zSupreme7
Could also be an alignment issue. Going to wider/lower profile tires will make any alignment issues much more noticeable.
Old Feb 6, 2009 | 12:39 PM
PikesPeakZ's Avatar
PikesPeakZ
Originally Posted by eZe323
Hey,
Thanks,
Common sense would say to have the balance checked on the wheels before putting them on.
Old Oct 23, 2011 | 08:53 PM
BYBYCOP's Avatar
BYBYCOP
Wheels for the Z must be "Road Force Balanced" or else you'll get a nasty vibration after 70 mph
Old Oct 24, 2011 | 12:18 AM
JDMStanced's Avatar
JDMStanced
my car vibrates like crazy when slowing down from 90~100 mph. i should get the rims rebalanced huh..
Do the unbalanced rims have an affect on normal driving locally?
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
