Weird issue (power windows)...
Old Mar 6, 2009 | 04:06 AM
kurt213's Avatar
kurt213
Default Weird issue (power windows)...
I finally took my Z out of storage yesterday, it's running great and everything. But I tried to roll down the passengers side window and it didn't work. I tried using both the drivers side switch as well as the switch on the passengers door. The drivers side window works fine, and there are no other issues with the car.
I'm just wondering what could have happened? What would have caused that? Has anyone else experiences anything like this?
I'm guessing the warranty will cover this....It just sucks I'll have to go through all of that. Anyone ever had anything like this happen? Is there anything I could try to remedy this myself?
Old Mar 6, 2009 | 06:38 AM
J350z101's Avatar
J350z101
Search.
Old Mar 6, 2009 | 06:49 AM
VO...'s Avatar
VO...
Administrator
Check the window lock switch located on the drivers door. It may be depressed...
Old Mar 7, 2009 | 10:04 PM
vthao's Avatar
vthao
Maybe the window motor took a dump
Old Mar 8, 2009 | 12:44 AM
jining's Avatar
jining
try hitting you first against the middle of the door around the area where the motor is... lot of the time it will go down, if so, your window motors going out most likely.
Also, im fairly sure that if the passenger switch is not working the drivers side switch will not operate the window...at least on some other nissans its that way, I havent tried a Z
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
