Driver side valve cover gasket starting to leak? What to do?
Old Feb 25, 2009 | 01:45 PM
JJ350's Avatar
JJ350
Default Driver side valve cover gasket starting to leak? What to do?
I just went in to my local dealership to get my oil changed, and after they changed my oil they informed me that my drivers side valve cover gasket is apparently starting to leak somehow (what could cause it?). So since I have an HKS supercharger installed on my Z, they told me that to get it fixed it would cost me $400 in labor, which means that the dealer is going to remove my supercharger to fix the valve cover gasket under warranty then reinstall it afterwords. Then when I asked them how much it would cost me if they wouldn't remove my supercharger, and they said that it would then cost me around $1,000. Now I have a few questions that I would appreciate some help with:
First of all how big of a deal is this, and am I at any kind of risk of damaging anything by having this leak?
Also, what should I do about getting it fixed? I think that since I would at least have to pay the stealership to remove and reinstall my supercharger anyways, should I probably be able to find a place that will do this job without removing my supercharger for a lot less then what the dealership will charge me (which seems like too much to me for what it is)?
And finally would it just be a bad idea to have the stealership mess with my supercharger anyways? I mean I paid good money to have GTM do my installation and tuning, so would it be possible that the dealership could possibly mess something up?
Old Feb 25, 2009 | 02:08 PM
SuperBlack350z's Avatar
SuperBlack350z
it's not too big of a deal. You just have to remove everything in the way to get to the valve cover itself. It's not too hard, i don't think you have to take off your whole supercharger, just the pipe that runs up to the throttle body.
And no, don't pay that much for them to switch it out. that's way too much.
Old Feb 25, 2009 | 02:14 PM
NISMO_558's Avatar
NISMO_558
can't you just change it yourself?
Old Feb 25, 2009 | 02:20 PM
jray8's Avatar
jray8
Have you been quoted for parts and labor from the company that installed your supercharger? As far as what would happen, you would just smell it burning and constantly be "topping off"
Old Feb 25, 2009 | 02:22 PM
Jay'Z's Avatar
Jay'Z
Dont let them rape you.. DIY!!!
Old Feb 25, 2009 | 02:26 PM
Nexx's Avatar
Nexx
i was about to say, rebuild and tt time!
Old Feb 25, 2009 | 04:10 PM
3-fifty-WeEe's Avatar
3-fifty-WeEe
just pull the damn thing off, like fak man are you that simple? its frickin basic work, figure it the hell out, im sick of STUPID newbs buying Z's and not knowing ANYTHING about cars. you people sicken me.
Old Feb 25, 2009 | 04:46 PM
JJ350's Avatar
JJ350
Damm dude, WTF crawled up your ***? I know plenty about cars, there is just the fact that I have no experience as a mechanic, and being that I am in college I am also unable to work on my car myself even if I wanted to. Way to jump to conclusions and be no help at all, ***!
Old Feb 26, 2009 | 12:02 PM
vthao's Avatar
vthao
LOL, a lot of old folks buy Z's and know nothing about them...you're an idiot.
If the dealership says that it's just "starting" to leak, then it's probably no big deal. They probably just saw a little wet area around the valve cover gasket. Now if you check your oil and have to consistently add a little every time, it would be in your best interest to get the problem fixed. As everyone besides smarty-pants has stated, it's an easy job.
Old Feb 27, 2009 | 06:55 AM
sir captian's Avatar
sir captian
Everbody isnt a gear head.
Old Feb 28, 2009 | 03:49 PM
silverbullet_Z's Avatar
silverbullet_Z
no it's not to hard you just need a torque wrench and a 10mm socket and a screwdriver i think is all you need. Oh and you will need to remove the strut bar so you'll need a... 14 or 16mm socket cant remember , but other than that basically everthing on the motor is 10mm
Old Mar 1, 2009 | 05:19 PM
JJ350's Avatar
JJ350
So is this something that I should address very soon, or should I be just fine for a little while? I just want to make sure that I won't be at any risk of damaging my engine by having this leak.
Old Mar 1, 2009 | 05:27 PM
Jay'Z's Avatar
Jay'Z
How did they say its leaking? Where? In the plug ring area? or at the valve cover? Id say its normal but I dont have any idea where your leak is..
Old Mar 1, 2009 | 07:50 PM
vthao's Avatar
vthao
Dude, you should be fine. There are usually no problems unless the leak is so big that you have to constantly refill your oil to get it to the proper level. If there's no smoke (heat from the motor/headers burning the oil), you're good.
Old Mar 1, 2009 | 09:00 PM
Lawy'dU's Avatar
Lawy'dU
change it yourself. This happens to pretty much everybody that adds boost
Old Mar 8, 2009 | 12:59 AM
jining's Avatar
jining
im assuming its leaking in the rear corner, they always seem to leak there... its not too bad to change really. Just remember where things go.
allmycarsdie
May 13, 2016 04:38 PM
May 12, 2016 07:42 PM
irishguy0224
Sep 22, 2015 06:57 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
