Look at my spark plugs..Should I be worried?
Old Mar 16, 2009 | 08:21 PM
SuperBlack350z's Avatar
SuperBlack350z
i got mine through a vendor for 150 each brand new.
Old Mar 18, 2009 | 05:03 PM
Zorgazm's Avatar
Zorgazm
Some of you are saying change your valve cover gaskets and some are saying change the actual valve covers. Which one is it? i would assume gaskets but what do i know?
Old Mar 18, 2009 | 05:09 PM
SuperBlack350z
valve cover gasket would cause oil to leak around your valve cover. Oil on your spark plugs would mean you have a bad valve cover since the holes inside the valve cover aren't sealing properly. Changing your valve cover gaskets will not effect your oil on the spark plugs.
Old Mar 18, 2009 | 05:26 PM
Parker01's Avatar
Parker01
Are they not just little O-rings pressed into a machined face on the underside of the valve cover? There must be something... it would be rediculous if they expected a metal-metal connection to seals. Try to find a pic of the underside of a valve cover, i'm going to do the same.
Old Mar 18, 2009 | 05:40 PM
SuperBlack350z
yes, there are o rings, but they are built into the valve covers. Some have used sillicone around them but it's a hit or miss doing it like that.
Old Mar 19, 2009 | 08:23 AM
VO...'s Avatar
VO...
Administrator
I do not believe they are seperate items if I'm not mistaken. It's all one assembly. Can someone confirm this?
Old Mar 19, 2009 | 09:38 AM
Asian Invasian's Avatar
Asian Invasian
I am pretty sure they are all one piece.
On a side note.. if I had just a small leak, can I get away with not replacing my valve cover gasket?
Old Mar 19, 2009 | 10:09 AM
0jiggy0's Avatar
0jiggy0
External oil leak? Ya your just going to have oil all over the place. Oil destroys electronics and rubber real fast, and your probly gonna get sick of checking it and something will get damaged. Change them before you have to change them and more ****.
Old Mar 23, 2009 | 04:11 PM
jb0's Avatar
jb0
I found the same issue on my car (#6 cylinder)... decided to pull the valve cover to have a look and took a few pics. The seals are in fact molded in the plastic and non removable.
Dr.Paulyy
Jul 29, 2019 07:45 AM
waldo36
Sep 20, 2015 09:13 PM
RyansZ33
Sep 15, 2015 05:54 AM
