Correct Brake Line Bleed Process
Old Mar 26, 2009 | 11:57 AM
enlite's Avatar
enlite
Default Correct Brake Line Bleed Process
is this correct?
Rear Right, Rear Left, Front Right, Front Left
Old Mar 26, 2009 | 12:09 PM
warmmilk's Avatar
warmmilk
https://my350z.com/forum/brakes-and-...ed-brakes.html
Old Mar 26, 2009 | 04:35 PM
davidmcc's Avatar
davidmcc
As per the factory service manual you want to bleed the rear right, front left, rear left, and front right tires, in that order.
Old Mar 27, 2009 | 05:32 AM
josesantigo57's Avatar
josesantigo57
You always do from furthest away from tank to closest, so Rear Right, Rear Left, Front Right, Front Left is correct.
Old Mar 27, 2009 | 06:40 AM
thekinn's Avatar
thekinn
Default 06 service manual says...
Bleeding Brake System NFS0000A
CAUTION:
While bleeding, pay attention to master cylinder fluid level.
1. Turn the ignition switch to the OFF position.
2. Connect a vinyl tube to the rear right bleed valve.
3. Fully depress brake pedal 4 to 5 times.
4. With the brake pedal depressed, loosen the bleed valve to let the air out, and then tighten it immediately.
5. Repeat steps 3, 4 until no more air comes out.
6. Tighten the bleed valve to the specified torque. Refer to BR-27, "Components" (Front) and BR-40, "Components"
(Rear).
7. In steps 2 to 6 below, with the master cylinder reservoir tank filled at least half way, bleed air from the front
Old Mar 27, 2009 | 08:42 AM
davidmcc's Avatar
davidmcc
except when the FACTORY SERVICE MANUAL instructs you to do it in a different order.
