poping sound from front!?
Does anyone have this problem? When the car is parked then i would put it in 1st then turn the steering wheel, then there would be a POP in the front! Does anyone know what this is? Is it my ball and joint or is it my tie rod? Dealer said they didn't hear anything! And they DON"T even have a certify tech for the Z car yet!
This is may not it, but just in case, check by searching for "pop" or "popping." I believe someone posted a while back about a popping noise when turning. In their case it turned out to be two loose bolts in the upper front suspension—I think on the passenger side. The dealer tightened them up to spec and it cured the problem.
Good luck.
Good luck.
Originally posted by the_bode
That's right--my car had the same problem, and it turned out to be a loose control arm in the passanger front suspension. Dealer torqued the bolts to spec, sound gone.
Originally posted by alex30327
Does anyone have a pic of the upper control arm bolts?
loljust find the torque spec for the bolt, go to whoever did your suspension for you, and tell them to torque the control arm to whatever the spec is. or use the german spec: goot n tight
Originally posted by julian
i'm sorry but that cracks me up. a fully modded suspension in your car but you don't know what the control arm bolts looks like?
lol
