Engine stalls on start up - plz help
Old Apr 2, 2009 | 11:11 AM
david79's Avatar
david79
Default Engine stalls on start up - plz help - with video
My '03 Z has been sitting in my garage for the last 6 months and now the weather is getting a little better, I decided to do some minor tune ups before I put her on the road. I did the basic, Oil change, air/oil filter. Checked all my fluids to see if anything needed be topped off.. anyways, When I fire her up the first time, everything was good...I decided to take her out for a couple spin around my neighbourhood. After doing so, I parked her back in the garage and waited till tomorrow to do other stuff (cleaning etc...) the next day, when I started her up, the engine would start but then the rpm meter will quickly drop back down to 0 and the engine comes to a halt. I've searched around the forum, that it could be the spark plugs with oil in them, or it could be the fuel injectors being rusted up for sitting for so long ...but they were fine the last summer. Anyone else have similar problem? there are no CEL code that lights up. dunno:
Here are videos if it makes it more clearer. is this due to bad gas??
Initial start up
http://www.youtube.com/watch?v=7nv8zQHajsc
Restarting/engine shuts off
http://www.youtube.com/watch?v=qyFnYJezgY0
Old Apr 2, 2009 | 11:37 AM
EvilCrayon's Avatar
EvilCrayon
Only thing I can think of is fresh gas....
Old Apr 2, 2009 | 11:42 AM
Spork's Avatar
Spork
Fresh gas, drive it around for a bit.
Old Apr 2, 2009 | 01:23 PM
kevincat's Avatar
kevincat
a shot in the dark here but by any chance you unplug the negative part of the battery? if so then you must have resetted the ecu.
and you might have to do a relearn.
oh and all this applies to manual only
Old Apr 2, 2009 | 01:28 PM
PerfZ's Avatar
PerfZ
I'm pretty sure that disconnecting the battery actually resets the ECU all by itself. And it doesn't matter whether it is MY or AT. I agree with bad gas, especially if he did not use Stabil or something similar.
Old Apr 2, 2009 | 01:40 PM
kevincat's Avatar
kevincat
i know that ecu resets with both at and mt. but i was referring to the rpm being low on manual when the ecu is reset
Old Apr 2, 2009 | 01:46 PM
PerfZ's Avatar
PerfZ
OK. but that has never happened to me either. Actually I have a high idle problem right now and even when I do the ECU AND TB Idle learning reset, it doesn't last. Might have a vacuum leak or something. Sorry to go OT here...
Old Apr 2, 2009 | 07:27 PM
david79's Avatar
david79
yah when i stored the Z i unplugged the battery, but I put the battery back in a couple of time to start her up twice in those 6 month that it was stored. The start up was good. I'm just hoping its the gas problem, cuz i didnt put any fuel stablilizer. Lets see what happens with a fresh tank of gas. Appreciate all the tips guys...Thanks
Old Apr 11, 2009 | 01:22 AM
Reyes5937's Avatar
Reyes5937
Did you ever get around to fixing the problem what was it?
Old Apr 14, 2009 | 07:01 PM
Z_Nick_Z's Avatar
Z_Nick_Z
BUMP!!! i have this problem
Old Apr 15, 2009 | 09:58 AM
david79's Avatar
david79
the tank is still full...i'm still trying to burn up the gas...May 1st when my coverage starts, so i'll be bringing her out on the highway.
right now everytime i start her up, she seems fine..purrrrrs like a kitten...
no problem yet...
Old Apr 16, 2009 | 11:04 AM
david79's Avatar
david79
I put up some video of my problem...I still have a full tank of gas, still does the same thing. I really hope its the gas problem.
Old Apr 18, 2009 | 04:29 PM
CAFDriftZ's Avatar
CAFDriftZ
Mine had the same problem last month when I started driving it when I was home from school since it was nice. A friend said it could be the throttle positioning sensor going bad. I've been driving it tho lately and took it to the track and haven't have any problems. I think it just needs driven a bit.
Old Apr 19, 2009 | 09:31 AM
McLovin350Z's Avatar
McLovin350Z
i 2nd this problem as well
Sometimes the car is fine.......and can drive it around no problem
then when i make a stop.....the car has trouble idling......i had to launch myself all the way home
Old Apr 19, 2009 | 09:35 AM
McLovin350Z
ive heard alot of ppl saying check your vaccum lines......what is the tool to help you detect leaks?
Old May 12, 2009 | 07:24 AM
Zenpato's Avatar
Zenpato
This happens to me everytime I unplug the battery , It usually goes away after a few fill ups may be the ecu re-learning. Did several searches but never found an answer.
Old May 12, 2009 | 08:43 AM
j.arnaldo's Avatar
j.arnaldo
Techron AND fresh gas??
Old May 13, 2009 | 01:14 PM
david79's Avatar
david79
I put in a fresh tank of gas and sometime it would idel down to zero and shuts off...but the last couple days, nothing...it starts fine...
Old Apr 15, 2010 | 06:16 PM
BluRed's Avatar
BluRed
I currently have this problem as well, just brought it out today and it happened. Samething happened last year but I forget how I dealt with it last year lol. When it would come closr to stalling, i would just rev it up a bit and then it would be good...
Old Apr 15, 2010 | 08:12 PM
ZYouL8R's Avatar
ZYouL8R
EDIT
