A/C Control System is acting different
Old Apr 8, 2009 | 08:39 AM
goslice's Avatar
goslice
Default A/C Control System is acting different
I used to be able to set my a/c control to 60 and the fan motor would blow full speed regardless of the inside/outside temps. Now, this only works when the car is very hot inside. Once the car is cooled down, setting the a/c temp control to 60 does not cause the fan to run full speed. I'm thinking maybe a sensor has gone bad or the a/c control unit itself is bad. It's a minor thing but I know this unit is designed to run at full speed heat and/or cold if you set the thermostat to 60 or 90. BTW, the 90 setting is still working fine (full heat). Any ideas or similar experience?
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
