issues with my 06
Old May 2, 2009 | 01:06 AM
GiftOfGab's Avatar
GiftOfGab
Default issues with my 06
car has 38,xxx miles mods include berk high flows, cat back, mrev2, plenum spacer, pop charger
recently ran upon several issues
engine cold or warm...under normal accelerating car struggles to gain power, engine sounds abnormal very loud around 2-3k, continues at high RPMs
the other day I punched it in 6th on the highway and the car lagged like hell, SEL flashed on then turned off..no light so I can't check for codes
talked to a mechanic could be...knock censor or MAF censor...need to check them asap
also if the car hasn't been driven for a few days a loud rattling sounds coming from below the motor after start up for a quick second then goes away
I found a few threads on similar issues but no conclusions.....I will post updates
comments/help would be appreciated
future mods pending
Old May 17, 2009 | 12:17 PM
cdoxp800's Avatar
cdoxp800
future mods pending
Have you checked the codes?
Old Jun 25, 2009 | 11:13 PM
GiftOfGab's Avatar
GiftOfGab
The problem was a blown cat that I purchased from a member here not to long ago(Berk HFCs) One was already damaged when I received the cats. I ended up gutting out both the cats so basically they are test pipes now. No more problems with the car.
apex locator
Jul 23, 2021 02:27 AM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
