Changing rear shocks... can I do it with my limited knowledge
on
2004 350z - stock
So, both my rear shocks are shot. The dealer wants $600 (parts and labor) to replace them, a local shop wants $340 (parts and labor). Can I do this even cheaper/better?
My knowledge of cars is limited. I have changed brake pads/rotors (disc only), changed the oil myself, installed air filters and I have sort of installed a water pump in an old cherokee...
So, are rear shocks something I an handle? I can rent the big tools from Autozone, I have jack stands, and a friend that is willing to help. Anyone have a guide/guidance/advice on this?
on
I put in my car at checkers and went to rear shock and this is what came up..
http://shop.oreillyauto.com/ProductD...artNumber=5795
does that work?
does that work?
If you know how to take the brakes apart to change the pads, this should be a walk in the park for you.
The rear shocks are one of the most straight forward installs for the Z since the shock stands alone from the spring. Just make sure you don't over-torque the top mounts.
Administrator
Rear shocks are a cake walk...
All you need is a floor jack, jack stands, two wrenches (its literally 4 bolts per side), some sockets, an extension for the two nuts at the top shock mount, and a torque wrench to put everything back together. As easy as changing the oil...easier if you count the 14 annoying undertray bolts.
does that work?
does that work?
Not sure what your budget is but consider a performance shock such as this. Reference: http://www.tirerack.com/suspension/S...lar=&brand=all
