for those of you that change your own oil
Old May 16, 2009 | 03:35 PM
tw8715's Avatar
tw8715
i hearded mixed reviews about the pump... that it dosnt get all the stuff at the bottom out~~~
hey is there a easier way to get the filter off without a mess??
i usually take the plastic underbody cover off when i do the oil change which is a PITA!
impossible to get the filter off without taking that out.. and making a mess~
any suggestions?
Old May 16, 2009 | 03:53 PM
Zenica's Avatar
Zenica
any suggestions?
This is why I am going to relocate the filter.
I did my oil change today and experimented a bit...using the Mityvac that I have which is a manual pump/extractor, I was able to get all but 1/4 of one quart out, for that I dumped some Mobile 1 down the oil fill and then extracted the missing amount. It took about 1 qt of Mobile 1 to help get that last 1/4 qt of dirty Royal Purple.
I too take that engine pan down and it is a PITA. With the filter relocated
to under the hood, my Mityvac extractor and 5 qts of RP with one qt of Mobile 1 I should be able to complete the oil change without ever taking that pan down again.
Old May 16, 2009 | 04:28 PM
alan86's Avatar
alan86
how did you relocate it? also you dont even have to take the underbody panel out to access the filter or the drain bolt.
Old May 16, 2009 | 06:08 PM
Zenica's Avatar
Zenica
I haven't relocated it yet...there are kits made so you can relocate it.
If you don't want oil anywhere it doesn't belong, removing the pan is best.
Old May 16, 2009 | 08:44 PM
StuLax18's Avatar
StuLax18
General & Tech Moderator
I've seen people make little trap doors in the belly pan to get to the plug and/or the filter.
Old May 17, 2009 | 12:06 PM
nothix's Avatar
nothix
really guys? you're complaining about changing oil?
Old May 17, 2009 | 01:08 PM
quakerroatmeal's Avatar
quakerroatmeal
^^ seriously lol...it's like a 10minute job even with the 15 bolts that the under body carriage uses....some of you guys are some girly *****.
Old May 17, 2009 | 05:45 PM
Zenica's Avatar
Zenica
Your entitled to your opinion I suppose.
I change my oil more frequently than some others and likely more than either
of you so anything that saves me from going under the car is worth it.
Until the two of you posted, this "conversation" was doing just fine...
Old May 17, 2009 | 06:29 PM
CircleHeartX's Avatar
CircleHeartX
Are you guys just allergic to oil?..
Dont be shy to admit it, i will understand it
Old May 17, 2009 | 06:36 PM
Zenica's Avatar
Zenica
LOL
Actually, clean motor oil is an irritant and not a toxin. Used motor oil can contain toxic substances such as benzene, lead, zinc and cadmium.
It isn't something I'd want to substitute for my Perlier.
Old May 17, 2009 | 11:19 PM
tw8715's Avatar
tw8715
just gets annoying to clean up any oil spill on the garage floor~
there is a little opening on the plastic underbody..
maybe i should try cutting it and making a larger whole for easier access?
what do you guys think? no harm rite?
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Stevo Z
Oct 3, 2015 09:14 PM
