Problem after problem....
Well my ses light turned on yesterday, car has 92,xxx miles so i took it to autozone to see what it was, well they told me it was the 02 senors.....
anyways on top of that idk what is wrong with the car, at a cold start it won't start....it'll crank but it won't start!! so that eliminates the possibility that its the starter, so what could it be????!!
MAF??, spark plugs??, injectors???
just give me any suggestions what it might be.....
(only three months with the damn car.....)
Really??
My 10 year old Acura 3.2 TL with 200k on the odometer has not
given me any issues since day one. The ONLY part I replaced was
the t-body (for the tp sensor) at 185k.
My 1991 Legend with 125k is still running strong as well...
My 96 accord has 200k and i have zero problems with it.....even after i modded it.
but back to what i was saying can o2 sensors really cause a bad cold start??
When you say cold, I take it that you mean over-night cold? Not parked for a few hours cold? Of course if the ambient temperature is 5 degrees, then a few hours will have the same affect as over-night. The reason I ask is that when it is over-night cold, the system is in open loop, meaning it is not even using o2 sensor data so they should not have any affect on starting the engine.
I've had 02 sensors out on my DD.. I never had a problem with cold start but the car did hesitate alot though going through the gears
well see i tried this morning (overnight) and it didn't start, but yesterday at work (befor the ses light turned on) i only left the car sitting there for 30min, before the previous time i turned it on, and it did the same thing.
so answer to your question is both overnight and after just sitting there for a while.
else and possibly not even sensor related. Someone can correct me if I am wrong but my understanding is when the car is in open loop, the computer is
ignoring sensor data and operating in a predefined a/f curve. Only after the engine warms up will the computer cycle to closed loop and use sensor data to adjust the a/f.
nope long distance.
Oh and it stopped having the starting problems,
also when i restart the ecu to turn off the ses light after driving for a couple minutes it turns back on.
ok i changed the o2 sensors but the ses light is still on...... i'll reset the ecu and soon after it turns back on.... took it again to see what codes came up and they were the same codes!!!
how could the o2 sensor code come up when i just replaced them!!!
what else could it be???
just because the codes are saying theres a problem with O2's doesnt necessarily means the O2s are the problem. @ 90k its not a bad idea to change them. Theres a reason places charge diagnostic time.
Could be the O2, cats, ecu, bad connection/wires.
well i'm going to get a diagnostic tomorrow instead of just getting a read from autozone, i also cleaned the maf with the cleaner to see if that was it so far it hasn't come on but of course it doesn't mean that it will not turn on again....
but for sure i'll find out tomorrow....
