heater/fan on full, can't switch off
Old May 22, 2009 | 11:50 PM
pez1111's Avatar
pez1111
Default heater/fan on full, can't switch off
Hi, just installed a Nismo Shift ****. While doing this i disconnected the heater/fan/a-c control panel from behind to get better access. After completing the shift **** install the heater/fan everything is on full. Pressing/turning the controls does nothing. Is there some sought of re-set? Has anyone had this happen to them? I hope i havn't cooked the module!!!!
Thanks in advance and the "search" didn't come up with this issue.
Old May 22, 2009 | 11:58 PM
jadaniya's Avatar
jadaniya
Hope you plugged it back in. If you didn't that's the obvious problem. If you did plug it back in, you didn't do it good enough. Plug it in better and the problem should to away.
Old May 23, 2009 | 12:05 AM
Mazinger Z's Avatar
Mazinger Z
plug it like joe biden
Old May 23, 2009 | 12:55 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
It's not plugged back in
Old May 23, 2009 | 02:49 AM
cheshirecat79's Avatar
cheshirecat79
So I heard it might be the plug
Old May 23, 2009 | 05:03 AM
350Zenophile's Avatar
350Zenophile
Plug it in! Plug it in!
Old May 23, 2009 | 06:13 AM
pez1111's Avatar
pez1111
Yeah i have done the plug, i'll give it another go tomorrow morning hopefully i'll get a better connection.
Thanks
Old May 23, 2009 | 03:14 PM
pez1111's Avatar
pez1111
DONE!!! In the light I could see a slither of plastic had sheared off and lodged on one of the pins.
Thanks for your replies.
sales@czp
Sep 23, 2019 03:30 PM
_bit
Oct 2, 2015 07:49 AM
