Hollow plastic rattling noise coming from the rear!!
Anyone have this? It happens only ones in a while on rougher roads, and it is a distinct hollow plastic rattle coming from the rear. Any fix or comments will help, thanks!
M.
M.
Originally posted by Shift_Speed
what about rattles in the guage cluster and the front passenger side and the rear view mirror even and the center compartment for those of us that didn't get navi.... RATTLES ARE GETTIN TO ME!
Not for sure about your rattle, but found mine to be the plastic cover on the hatchback. The plastic retainers holding the hatchback panel had loosened up/lost their tension and were allowing the panel to rattle. You can verify this by opening the hatchback, pushing firmly around the entire perimeter of the panel to reseat the retainers, gently close the hatchback and go for a test ride. Chances are the rattle will be gone, BUT it'll come back as the panel again loosens up. Have your dealer replace all the plastic retainers.
I have been being driven crazy by a rattle seeming to come from the three center gauges. Finally figured out what the problem was today, but don't have a clue how to fix it. I have the Nav, and drive with the door open all the time so i can use the screen. It turns out it is the open door that is rattling on me. Close the door, no rattle. Try it. You can replicate the rattle by simply hitting your dashboard around the gauges in the center. Open= Rattle, closed=silence. Glad to have found the fix, but this isn't right... I miss my nav screen. any ideas?
i had the same problem with my z rattles!! took it to dealers they cant do crap cuz they cant find the problem. my door panel was also rattleing does anyone else have this problem? like the bass of that sh IT TY sub was to loud lolz and i hear this noise coming out of the door panels.
M.
M.
Originally posted by alex30327
This is an easy fix. I had the same problem that only got worse once I installed the stiffer Nismo suspension. The rattle is coming form the rear strut brace. there is s piece of plastic that "slaps" aginst the brace when you go over certain bumps.
what about rattles in the guage cluster and ...the rear view mirror
Any solutions to these two problems would be of great help.
Originally posted by hypersonicaz
I have the exact same rattles coming from the gauge cluster and the rear view mirror. The cluster sound doesn't go away when the door is up, as Moodie suggested (my Nav door is usually down). The rear view mirror squeak often comes when music w/ heavy bass is playing, and temporarily goes away if I give it a good upwards push.
Pics would definitely help!
However, I am quite certain it is my mirror. When I push up on it, an audible "click" can be heard, and the buzzing stops (I even fiddled around quite a bit with the wire coming from the Homelink, which also seemed to be contributing).
But I'd like to try your solution as well!
M.
M.
I get a chirping noise coming from the back. Dealer looked at it and order some part. Once that comes in, I'll post more info.
Moodie, as far as the rattle from the front, I haven't heard it since they replace the cable. Gonna have to take it up Mt. Hamilton to see if that fixed the play in the steering. Also there was a TSB for rattling in the VDC button area.
I think Nissan did address the rattling in the later models... I don't hear any rattling in failsafe's car. His was deliver in Feb.
Guys, if you click on the "resources" button at the top of this page (under the logo) you will find all the TSB's. There is a TSB for fixing of some of the rattles and squeeks you mention.
Hope this helps.
As always
H
Hope this helps.
As always
H
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
