Help!! Rev can't get higher than 1800rpm
Old Jun 12, 2009 | 07:26 AM
hjz33's Avatar
hjz33
Originally Posted by 350 Rookie
LOLOLOL. Oh man, you are funny.
Btw, you dont need to take both wires off. If you take off just the ground (black or -), it will do the same thing.
but by doing that, will anything happen to my battery suck like it will die quicker than normal or something. I know it sounds funny, when I am talking all these none sence stuff, but as no one really knows about the Z that much in this country all I can do is learn everything by myself. don't know if I should be happy about it.
Old Jun 12, 2009 | 08:34 AM
Xlr82x's Avatar
Xlr82x
Always disconnect negative terminal first. Its a precaution so if you are doing the positive first, you dont slip and hit the frame and ground it. Then you might have biggere problems.
I think he means to disconnect the positive first. You can always ground something out but can't ground anything if the red wire isn't on the battery... You disconnect the negative first and leave the positive still hooked up, you going to cause sparks and the ground wire to weld to what ever it touches.
Old Jun 12, 2009 | 10:18 AM
350 Rookie's Avatar
350 Rookie
Someone get xlr82 a pen and paper for some notes.
Here is the lesson to be learned. The ONLY reason you disconnect the negative first is to be safe. Its a PRECAUTION.
FOR EXAMPLE. Let say you are tryin to take off the positive first and suddenly your wrench/ratchet slips and hits the wall or any ground, then you will short circuit the whole dman system and risk taking out a Control Module.
BUT if you take off the negative and you slip and hit the wall or ground, nothign will happen.
EITHER WAY, you can take off any cable to create an open circuit but takin off negative first is safer and less chances of damaging anything.
Old Jun 12, 2009 | 10:22 AM
350 Rookie's Avatar
350 Rookie
Well you dont have to really know about z's to work with a battery. And trust me on this one, take off negative first. Nothing is worst than knowing all you had to do was listen and you coulda prevented a blown fuse or something even worst.
Old Jun 13, 2009 | 07:14 AM
hjz33's Avatar
hjz33
cool, I did some search, and looks like take the negative off frst is rght? but if I only loos the negative side and when I try to put it back will it sparkle.
Old Jun 13, 2009 | 07:15 AM
hjz33's Avatar
hjz33
Can somebody teach me how to post pics on this fourm!!!!!!!
please please please
Old Jun 13, 2009 | 07:29 AM
hjz33's Avatar
hjz33
btw, what tools do I need to disconnect my battery?? Please not the very cheap ones that may get me killed.................
Old Jun 13, 2009 | 04:14 PM
350ZTheStandard's Avatar
350ZTheStandard
BOlt cutters or a hack saw, your choice. Just make sure the engine is runnIng.
Old Jun 17, 2009 | 02:32 AM
hjz33's Avatar
hjz33
ok, since I have to do everything by myself now I think it's better for me to learn more about cars as much as I can. so anyone can suggest me some book or computer programs to learn how to fix my Z. I mean teachs me to do everything that's need to be done on my Z.
And I still need somebody to teach me how to post pic on this fourm.
Old Jun 24, 2009 | 04:20 PM
xcessiveskllzz's Avatar
xcessiveskllzz
Wouldn't a vaccum or boost leak also send a car into limp d*ck mode?
Old Jun 24, 2009 | 08:10 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
i think ur the best tool 4 the project
Old Jun 24, 2009 | 09:46 PM
hjz33's Avatar
hjz33
ok the newest report is that the throttle gains the the response back, but the vdc light and the engine check light is still one, what I did is borrow a battery charger and charged my battery for a night. well, at least I can drive the car to a shop to see what's going on with my freaking Z. hope there will be no problem for my Z. Thanks for everyone's help.
Old Jun 24, 2009 | 09:52 PM
350ZTheStandard
^ welcome to the forum
Old Jun 27, 2009 | 08:17 AM
hjz33's Avatar
hjz33
check engine light is still on, will take it to a shop and see if anything's wrong with my Z.
Old Jul 24, 2009 | 11:40 AM
pachuco's Avatar
pachuco
what ended up being the problem? Kinda have the same issue
Alexreyes
Sep 30, 2015 11:30 PM
