Problem after installing new battery...
Old Jul 27, 2009 | 04:39 PM
coletrain12's Avatar
coletrain12
Default Problem after installing new battery...
Hey guys, have a 2003 350z touring. The dealership told me the battery was near failure and the starts sounded a little weak, so I went and purchased a new battery.
After installing the new battery, when starting the car after it starts fine the idle goes down almost all the way to 0 like it is going to die but then comes back up to normal idle.. but sometimes it does die. Any idea as to what caused this?
Thanks,
Cole
Old Jul 27, 2009 | 05:29 PM
Not unusual after disconnecting battery.
I got a new battery several months ago. RPM would drop to zero stalling the car. Instead of doing the ECU reset thing, I left it alone. Car was fine after a few days.
Old Jul 27, 2009 | 09:02 PM
ZKansasZ's Avatar
ZKansasZ
https://my350z.com/forum/maintenance...a-battery.html
Old Jul 28, 2009 | 06:31 PM
coletrain12
Ok guys, im just going to leave it alone and see what happens. Now it only does it sometimes... this morning it started fine but when i left work it tried to die again.
Just going to give it more time i guess.
Old Aug 4, 2009 | 05:06 PM
coletrain12
Ok guys, UPDATE!
It seems the car has gotten better about the stalling/low RPM. It never does it like in the morning when i leave for work or when I leave work in the afternoon. It seems it does not do it after it has been sitting for a while.
However, if I turn the car on, then shut it off and try to restart it in a small amount of time it will still go low RPM and even stall sometimes.
Should I just keep driving it? Or could it be some other problem? I mean its been a while since I changed the battery, i figured it would be worked out by now.
Old Aug 18, 2009 | 03:47 AM
Originally Posted by coletrain12
Ok guys, UPDATE!
The battery does not determine idle speed. The ECU does. Do the manual reset thing.
Old Aug 29, 2009 | 04:45 PM
Did you try the manual reset? How did that work?
Uriyo_
Sep 8, 2021 08:46 AM
