1st to 2nd shift always bad
Old Aug 4, 2009 | 11:31 AM
scotts300's Avatar
scotts300
Isn't that for when you have a dog box? No need on any stock vehicle. But the civic guys like to , even when there is no need or HP.
Just be smooth, its that simple. Most cars cannot be slam shifted without grinding , thats probably what your doing.
Yes, I was just doing a FnF pun and joking with the OP.
Old Aug 4, 2009 | 11:34 AM
JCat's Avatar
JCat
I've had 5 trannys in my Z since 3/2004. Some were real lemons.
Don't let folks tell you that you are doing it wrong. Some of these trannys are garbage. The version 010 (it took Nissan 10 tries LOL) is better than priors.
Old Aug 4, 2009 | 08:35 PM
quietkilla6's Avatar
quietkilla6
Originally Posted by Dark8lue
if your grinding second a lot yo u could also be coming across a bad synchro...
My z has bad syncros and nissan wont fix it under warranty unless the transmission nolonger works at all.
Originally Posted by DemitriHKS
like kiriller said, shift sooner at like 2k or 2500 rpms and its a lot less noticeable. My friends evo is the same way and it urked the crap out of me. I started shifting sooner and it goes away. Either that or when you shift higher just make sure you keep your foot on the gas a bit too and that helps as well.
if i shift at lower rpms it acctually make it more evident.
Old Oct 31, 2012 | 09:39 AM
Jbakes727's Avatar
Jbakes727
Originally Posted by johnha209
what i do is when im going from 1st to 2nd... i dont pull it straight down to 2nd.. i move it slightly into neutral but not completely into neutral and then down to 2nd... it makes it a lot smoother... hope that makes sense
You are a genius! i just tried this in my Z because my 2nd is a little rough, all other gears are fine. It is just simply amazing how much smoother my 2nd is!!!
Old Nov 2, 2012 | 06:03 AM
whatZheck's Avatar
whatZheck
Hey, I am kind of a noobie still, but I think there is a plate beneath the shifter that is adjustable. I thought I saw someone mention proper alignment in a thread, specifically for first to second shifts.
Old Nov 3, 2012 | 06:20 AM
Tackett's Avatar
Tackett
When I first got mine I had an issue with the 1-2 being rough and jerking my guts out.
Clutch to neutral, release, clutch to second. Much smoother.
Sometimes I just skip first all together and use 2. You can pull out of 2 almost every time unless your on a very steep hill.
3-2 was bad too until I leaned to heel-toe.
Old Nov 3, 2012 | 09:40 AM
bbs350z's Avatar
bbs350z
if you cant find it, grind it.
Old Nov 6, 2012 | 06:10 AM
djamps's Avatar
djamps
1-2 is hell at redline but fine on normal driving with my CD008 ('04.5). Always has been. CD009 swap seems the only 'sure' fix.
Old Nov 10, 2012 | 08:17 AM
Haptic's Avatar
Haptic
Not sure if you're aware but starting in second will burn up your clutch very quickly...
Old Nov 10, 2012 | 12:51 PM
booba89's Avatar
booba89
I have the same problem with my clutch. I've only had the car for a week so i'm still somewhat getting used to the clutch but this is the first time i've been so jerky when driving a stick. I have the 06 model and it seems like the rev-up engine's rpm doesn't drop as fast for me. Like when i disengage from 1st gear my rev seems to hang a little bit before dropping and when i re-engage into 2nd i need to wait half a second for the rev to drop so i can engage without a jerk.
Can't tell if it's the car or me, hopefully it's just me and i can get used to it that way i don't have to change anything out on the car. =/
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
