help! vcd light stuck on...
Old Aug 12, 2009 | 07:28 AM
N3M3SiS's Avatar
N3M3SiS
Default help! vcd light stuck on...
just got my Z back from the body shop and now the VCD light is stuck on, no other lights, just this one.
press the button and nothing happens...
thanks for all the help in advance!
Old Aug 12, 2009 | 08:28 AM
Lcat84's Avatar
Lcat84
I've had this happen to me after I've spun out and stuff before. Not sure how it gets screwed up, but it should reset it once you turn the car off.
Old Aug 12, 2009 | 09:41 AM
N3M3SiS's Avatar
N3M3SiS
its still on, hasnt went off :/ not looking fpward to fixing it lol
vcd and slip lights are both on, abs is not
Old Aug 12, 2009 | 09:54 AM
Lcat84's Avatar
Lcat84
Sounds like the body shop may have bumped some wiring loose while your car was there. I'd try looking for some loose connecters.
Old Aug 12, 2009 | 02:32 PM
DavesZ#3's Avatar
DavesZ#3
Ahhh... you left out an important detail there from your first post.
From the owners manual....
Vehicle dynamic control (VDC)
off indicator light (if so equipped)
The light comes on when the vehicle dynamic
control (VDC) off switch is pushed to OFF. This
indicates the vehicle dynamic control system
and traction control system are not operating.
This light also comes on when the ignition key is
turned to the ON position. The light will turn off
if the vehicle dynamic control (VDC) system is
operational.
When the vehicle dynamic control off indicator
light and slip indicator light come on with the
vehicle dynamic control system turned on, this
light alerts the driver to the fact that the vehicle
dynamic control system’s fail-safe mode is operating,
that is the system may not be functioning
properly. Have the system checked by your
NISSAN dealer.
If a malfunction occurs in the
system, the vehicle dynamic control system
function will be canceled but the vehicle is still
driveable. For additional information, see “Vehicle
dynamic control (VDC) system” in the “5.
Starting and driving” section of this manual.
Old Aug 13, 2009 | 05:38 AM
N3M3SiS's Avatar
N3M3SiS
AWESOME!!!
thank you very much! couldnt find anything in the manual. ill be taking it to nissan today!
Old Oct 28, 2013 | 11:16 AM
GreenleafRacing's Avatar
GreenleafRacing
Hey man, I have the same issue... What was the resolution? I have heard from a friend that it is probably the cam sensors? Just curious as to what fixed your problem. Thanks!
Old Oct 28, 2013 | 11:21 AM
travlee's Avatar
travlee
Master
did you really just post a question on a threat that was dormant for 4 years???
smh
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
