rough idle
Old Sep 1, 2009 | 10:35 AM
033fftz's Avatar
033fftz
Default rough idle
hello i just put on my injen catback exhaust and since then i have noticed a rough idle it the shifter shakes and moves alot is this normal or is there something wrong?
Old Sep 1, 2009 | 11:29 AM
vthao's Avatar
vthao
Your catback has nothing to do with a rough engine idle. Rough idle = misfire/vacuum leaks/bad motor.
Old Sep 1, 2009 | 01:47 PM
DavesZ#3's Avatar
DavesZ#3
Check for leaks at the flange between the cats and your exhaust system. You did use a gasket there, right?
Old Sep 1, 2009 | 07:18 PM
033fftz's Avatar
033fftz
yeah i used a gasket and theres no way i could have a misfire me and my friends s2k are dead nuts and hes got gears and a full exhaust so idk ill check everything maybe its a vac leak cause it wasnt doing it before that?
Old Sep 1, 2009 | 08:05 PM
033fftz's Avatar
033fftz
does the grounding wire in the back have anything to do with it? lol
Old Sep 2, 2009 | 09:02 AM
vthao's Avatar
vthao
Nope. Mine's broken
liqalu04
Jan 2, 2022 12:58 PM
ablaine
Nov 29, 2016 10:13 AM
bneumann
Oct 7, 2015 12:16 PM
Darkspy
Sep 7, 2015 09:09 PM
