Occasional starting problem.
Old Sep 8, 2009 | 09:04 PM
md350's Avatar
md350
Default Occasional starting problem.
Every few days or so, when I turn the car on....the engine fires up and the rpms fall down to 0 and it turns off within a second. And it will keep doing this, until I turn it on and give it some gas/bring up the rpm's myself.
Any potential reasons why this would be happening? It never completely fails, because every time I give it some gas it stays on just fine. But why?
Old Sep 9, 2009 | 06:48 AM
VO...'s Avatar
VO...
Administrator
Moved...
Old Sep 9, 2009 | 10:43 AM
vthao's Avatar
vthao
Fat a$$ vacuum leak? Check your MAF sensor. You can clean this by spraying a little carb cleaner into it and letting it air-dry.
Old Sep 10, 2009 | 10:29 AM
j.arnaldo's Avatar
j.arnaldo
Diagnostics Center; hook up; read results; solve prob'!
Old Sep 22, 2009 | 08:40 AM
ttbbsolid's Avatar
ttbbsolid
mine started doing this too.
md350, did you find the cause yet?
Old Sep 23, 2009 | 10:52 PM
Zenpato's Avatar
Zenpato
Have you installed a CAI or Plenum spacer recently ? disconnect the battery for any reason? try checking the intake for leaks and a dirty MAF sensor as VTHAO stated.
This happens to me everytime I disconnect the battery , takes about a month for the ECU to relearn and go back to normal. Seems to be a pretty common problem...
liqalu04
Jan 2, 2022 12:58 PM
Uriyo_
Sep 8, 2021 08:46 AM
3vilbunny
Jul 18, 2017 05:10 PM
