2003 350z base fuel gauge problem
Old Sep 21, 2009 | 06:38 PM
michaelmyers's Avatar
michaelmyers
Default 2003 350z base fuel gauge problem
I just bought a 2003 350z base on Friday night, and after I bought it the seller told me that it needs a fuel sensor replaced. My fuel gauge is reading incorrectly how much fuel it is carrying. Where can I find this part? Hope you guys can help, thanks
Kenny
Old Sep 21, 2009 | 07:09 PM
I am always confounded when members ask where to buy OEM parts. Isn't the answer obvious or am I missing something?
Old Sep 21, 2009 | 07:14 PM
michaelmyers
Well I guess I asked incorrectly, but is it just one part, or several senors I need. Has anyone ever came across this problem?
Old Sep 21, 2009 | 07:39 PM
There are two sending units inside the tank:
25060Y
350Z SENDER UNIT-FUEL GAUGE
25060YA
Both operate with a float mechanism like inside a toilet tank. Unfortunately access to the units is from the top of the tank.
Old Sep 22, 2009 | 05:08 PM
can'tZme's Avatar
can'tZme
I have the same problem. I have already replaced one of the sensors and it helped a little bit. Im replacing the other one this week. I will let you know what happens.
Old Sep 22, 2009 | 05:10 PM
bad 350z's Avatar
bad 350z
i have every thing u need for sale pm me and let me no..
Old Sep 24, 2009 | 11:25 AM
michaelmyers
Please let me know, I want to get it done asap. I hate guessing how much fuel I have left, thanks!
Old Sep 24, 2009 | 06:42 PM
can'tZme's Avatar
can'tZme
Ok. Mine is fixed. My fuel guage went crazy like a year ago. It went from full, to half, to empty, to half, to full, etc. etc. Then it only stayed at empty. So I finally gave in and bought the secondary fuel level sensor (behind drivers seat). I got it from ebay. A guy on there had like 5 of them for around $50 or $60. After I installed it my guage showed half but never anything more and then it would drop to empty at its normal rate. I couldn't find the other fuel level sensor (behind passenger seat) anywhere accept the dealer. So I had them order me one and it was $117. For this one you have to drain as much fuel out of your tank as possible and the whole fuel system. Completly remove the fuel pump and carefuly remove the fuel level sensor on the side of it without breaking it. It took me a good 30 min to get it off. Pop the new one it. Put the fuel pump back, add some gas, and there ya go. Problem solved, well for me anyways. I think this is 99.9% of peoples problem. Oh yeah, if you do this yourself tell the dealer to order you two new "O" rings that go around each opening on top the tank. You cannot use the olds one because once you remove them the expand in diameter and no longer fit. Hope this helps and good luck.
Siqcology
Sep 18, 2019 01:45 PM
1973camarolt
Drivetrain
Oct 11, 2015 01:26 PM
FromGtoZ
Sep 20, 2015 03:41 PM
RWDBajan
Sep 8, 2015 06:25 AM
